Re: To rebuild on a budget or not: What to do with my 383 ?
[Re: ahy]
#830716
10/16/10 12:06 AM
10/16/10 12:06 AM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
A healthy 383 is a great engine. I'd do the basic rebuild and keep it going strong. With a healthy engine you will enjoy driving it and taking care of it also.
A 383/4-speed is how I always imagined the car to be. I'm there, with a fresh 4 speed but after redoing fuel/suspension/eletrical and so much else....I cant decide where to stop this snowball.
I'd be lucky to put 1000 miles a year on it.
[Re: JohnRR]
#830718
10/16/10 12:16 AM
10/16/10 12:16 AM
AlexP
Houston, Tx
Have you cc'd the heads to see what they are ?
Not yet. I'm going to clean them out in a few days and we might even flow them just for giggles. I didn't even notice that I've got HP2 Heads until today
[Re: DusterKrazy]
#830720
10/16/10 01:36 AM
10/16/10 01:36 AM
RapidRobert
Buy a cheap rering kit plus a cam/lifters for several hundred w your current over/under size of rings/bearings (most likely std). Rent a ridge reamer & pay someone who knows how to properly use it (pull the cutter toward you dont push it and dont remove all the ridge). Different opinions on this but I would suggest Moly rings (several $$ more) and read "breakin secrets" at www.mototuneusa.com (5 minute read). You'll be set for quite awhile until you get your good eng going.
[Re: HealthServices]
#830722
10/16/10 02:11 AM
10/16/10 02:11 AM
AlexP
Houston, Tx
Stroke it!
When I build my big hp 440 or maybe a new hemi in a few years it will be mean. For now it needs to just be done right and not give me issues.
[Re: 1_WILD_RT]
#830724
10/16/10 03:08 AM
10/16/10 03:08 AM
DaytonaTurbo
Manitoba, Canada
I agree, leave it. At most, do a hone'n're-ring with a new set of hastings cast rings and a drill mounted hone/deglazer. Rings + HV oil pump, hd intermediate shaft, 7 quart oil pan, cam, headers, heads and intake is what I did to my tired 70's smogger 440 and it real pretty good for what it was. Nothing ever let go on it.
