b body pitman arm dust boot #830526
10/15/10 04:10 PM
10/15/10 04:10 PM
NY, Monroe County
70RRJim Offline OP
70RRJim  Offline OP
NY, Monroe County
Hi
the boot over the rotating knuckle which functions like a tie rod end on my steering arm is torn and needs to be replaced. I can not find this at the local auto store and have no luck with a internet search. Anyone know where this item can be found, last thing I want to do is buy a new steering arm $$ for a low cost grease boot. I will not reinstall without a boot though.
thanks Moparts
Re: b body pitman arm dust boot [Re: 70RRJim] #830527
10/15/10 04:48 PM
10/15/10 04:48 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The Help section at your local Vatozone sells generic boots, considering where the stuff is made the life span is ??? Or you can get a poly one from a place like PST, maybe energy suspension? That boot is the same on all the pitman arms so you don't necessarily have to buy the $150 arm to get one .
Re: b body pitman arm dust boot [Re: JohnRR] #830528
10/15/10 04:52 PM
10/15/10 04:52 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
2835896 @ your local MoPar dealer.......
This space available for rent
Re: b body pitman arm dust boot [Re: cptn60] #830529
10/15/10 04:53 PM
10/15/10 04:53 PM
JohnRR Offline
JohnRR  Offline
Re: b body pitman arm dust boot [Re: JohnRR] #830530
10/15/10 05:18 PM
10/15/10 05:18 PM
cptn60 Offline
cptn60  Offline
Whatup with th popcorn? 199 in stock @ national pdc right now.
Re: b body pitman arm dust boot [Re: cptn60] #830531
10/15/10 05:45 PM
10/15/10 05:45 PM
JohnRR Offline
JohnRR  Offline
I'm hungry ... how much are they ?
Re: b body pitman arm dust boot [Re: cptn60] #830532
10/15/10 05:46 PM
10/15/10 05:46 PM
NY, Monroe County
70RRJim Offline OP
70RRJim  Offline OP
NY, Monroe County
thanks for the input, alreay went down the road of the generic boots in the help parts, none were applicable. I will follow thru on the part# at my Mopar dealer. It was not in the plan to spend big $$ for a low $$ part, just needed to figure out where or if the part existed. Thanks for the quick response.
Re: b body pitman arm dust boot [Re: 70RRJim] #830533
10/15/10 05:58 PM
10/15/10 05:58 PM
cptn60 Offline
cptn60  Offline
yeah thats the catch. list is $42.60 it does show all the boots across the linkage to be the same, maybe if you had a parts car?
Re: b body pitman arm dust boot [Re: cptn60] #830534
10/15/10 06:01 PM
10/15/10 06:01 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
I went down this road with an A body pitman arm. Most replacements don't even come with boots anymore, just a felt washer. Steer And Gear has them though apparently.
http://www.steerandgear.peachhost.com/ct_CGpitmanarms.htm
