Interference between torsion bar & tie rod end link #830483
10/15/10 03:19 PM
10/15/10 03:19 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
What’s my problem??? I reassembled my ’73 Challenger (which included removing the torsion bars) front end suspension and notice that the driver’s side tie rod end link that connects to center link, contacts the torsion bar when I turn the steering wheel.
As you can see from the picture, the top of the end link and the pitman arms are in line with the lower portion of the driver’s side torsion bar. Consequently when the steering wheel is turned to the right they contact one another. I have not placed the wheels on the car and dropped it on the ground however, I don’t recall experiencing this interference problem when I have previously performed K-member removal and front end reassemblies. I did place a jack underneath the lower control arm and loaded the front driver side which did not appear to alleviate this interference. The car is not aligned or ride height set. The passenger side does not have any interference with the torsion bar when rotating the steering wheel.
Initially I thought the pitman arm was incorrect which may have placed the centerlink in an incorrect position. However, I eliminated that the pitman arm is incorrect. I double checked and the torsion bar are correct for each side; driver’s side (left), passenger side (right). The centerlink is not backwards or flipped over either. Everything was bolted up and initially I did not notice the interference since I had everything pointed straight. I did replace the steering box with a Firm Feel however, they assured me that it’s not the issue and comparing it to another ’73 Challenger, the pitman arm’s drop appears to be in the correct position. I double checked the outside tie rods and they are correctly orientated on the lower ball joint. At this point, I’m lost what else it can be. The only other thing I’m thinking is could I have clocked the torsion bar into the lower control arm at an incorrect position when reassembled them and would that have any affect?
Any ideas???
Re: Interference between torsion bar & tie rod end link [Re: cruzin] #830484
10/15/10 03:35 PM
10/15/10 03:35 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Does the tie rod end go in from the bottom side? I'm not familiar with the E-bodies, but looking at the picture it would sure give a lot more clearance.
Edit: C-bodies have the shank of the tierod parallel to teh ground, so the rod end mounts to the back side of the centerlink, and that's what I'm familiar with. I just saw a pic of a B-body and it's rod ends come from the top like is shown in your picture. I dunno.
Re: Interference between torsion bar & tie rod end link [Re: cruzin] #830485
10/15/10 03:55 PM
10/15/10 03:55 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
... I have not placed the wheels on the car and dropped it on the ground however, I don’t recall experiencing this interference problem when I have previously performed K-member removal and front end reassemblies. I did place a jack underneath the lower control arm and loaded the front driver side which did not appear to alleviate this interference. The car is not aligned or ride height set.
I'd recommend putting wheels on and putting the car on teh ground and set it at a reasonable approximate ride height via a floor jack and see how things look. (probably won't change the results, though, unless you didn't get the LCA in the right attitude earlier when you were evaluating it with the jack).
The T-bar rides in the pivot for the LCA, so if you had the bar clocked/reversed, etc, that would show up in suspension behavior, not in the geometry regarding the tierods. the T-bar woudl either not hold the vehicle up or if it was clocked incorrectly you would not be able to set ride height within the range of the adjuster bolt.
So unless your frame, K-member, structure, etc is tweaked, I would look at steering component geometry again.
Re: Interference between torsion bar & tie rod end link [Re: cruzin] #830486
10/15/10 04:58 PM
10/15/10 04:58 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That height is set by the pitman arm I don't think setting the wheels on the ground and loading the suspension is going to change where the pitman arm is sitting , if it does you have bigger problems.
Do you have the steering box centered ?
Re: Interference between torsion bar & tie rod end link [Re: JohnRR] #830487
10/15/10 05:18 PM
10/15/10 05:18 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
I believe so. As I recall the steering box mounting holes are fixed and do not provide for movement/adjustment. I think there are three stout bolts which affix the steering box to the K-member.
The shank of the gear box, where the pitman arm attaches appears to be in the proper location when I compared this to another '73 Challenger.
Re: Interference between torsion bar & tie rod end link [Re: cruzin] #830488
10/15/10 05:43 PM
10/15/10 05:43 PM
JohnRR Offline
JohnRR  Offline
When I say centered did you spin it thru it full range of motion and get it in the middle of turns lock to lock ?
Re: Interference between torsion bar & tie rod end link [Re: JohnRR] #830489
10/15/10 06:34 PM
10/15/10 06:34 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
I gotcha.... According to the company, they ship them centered. Prior to mounting, I indexed/marked the shaft with the case in case it got out of alignment during installation or when assemblying the pitman arm, center link etc.
It seems to be centered having turned the wheel as much as possible from side to side and judging how the steering wheel aligns.
Re: Interference between torsion bar & tie rod end link [Re: cruzin] #830490
10/15/10 06:49 PM
10/15/10 06:49 PM
ontario canada
426lloyd Offline
426lloyd  Offline
ontario canada
I am having the same problem with mine after a front end rebuild but mine is a B body . tried every thing for weeks now still no luck . every one says the pitman arm is too short , but it is no different than the old one .although if it were longer it would solve the problem or putting the tie rod in from the bottom. If anyone has an answer let us know. thanks
Re: Interference between torsion bar & tie rod end link [Re: 426lloyd] #830491
10/15/10 07:56 PM
10/15/10 07:56 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
I thought it may be the pitman arm too. I purchased another one to make sure I didn't have a "manual" steering pitman arm instead of a "power steering" pitman arm.
Is your issue with the driver side too?
Re: Interference between torsion bar & tie rod end link [Re: cruzin] #830492
10/15/10 08:16 PM
10/15/10 08:16 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
is that the original kframe?
Re: Interference between torsion bar & tie rod end link [Re: chache876] #830493
10/15/10 08:41 PM
10/15/10 08:41 PM
MN
astrobuf Offline
astrobuf  Offline
MN
I think you have the tie rod end in backwards. The inner and outer tie rod ends are different. The stud length is longer on the outer end if memory serves. I just did this on my '71 Challenger and put them in backwards myself. Pull the rod end-sleeve assy out and swap end for end.
I suspect if you look closely, the present inner tie rod end castelated nut is way down on the stud and the cotter key is not closely engaged either.
Astrobuf
So, are you really a Rocket Scientist?
Re: Interference between torsion bar & tie rod end link [Re: cruzin] #830494
10/15/10 08:51 PM
10/15/10 08:51 PM
ontario canada
426lloyd Offline
426lloyd  Offline
ontario canada
yes it is the driver side also , and original K frame , just all new front end kit from moog . will check the tie rod ends to see if they are backwards, never thought of that being different .
Re: Interference between torsion bar & tie rod end link [Re: 426lloyd] #830495
10/15/10 08:56 PM
10/15/10 08:56 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
dont the tie rod go in from under the bar?
Re: Interference between torsion bar & tie rod end link [Re: mcmopars] #830496
10/15/10 09:02 PM
10/15/10 09:02 PM
ontario canada
426lloyd Offline
426lloyd  Offline
ontario canada
the old one was on top on my 66, is there any reason why it can't go on the bottom ?
Re: Interference between torsion bar & tie rod end link [Re: mcmopars] #830497
10/15/10 09:02 PM
10/15/10 09:02 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
never mind, i think it goes in only one way
Re: Interference between torsion bar & tie rod end link [Re: mcmopars] #830498
10/15/10 09:51 PM
10/15/10 09:51 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What's going on with the idler side of things?...
If the idler is low for whatever reason, the centerlink will pivot at the pitman joint. And then the driver side tie rod will move up toward the T-bar. Looks a little turned up, but could be the power of suggestion.
Do you have your old idler? How does the geometry of it look compared to the new one?
Do you have another centerlink to compare against? Careful they look bent when they are perfectly fine if you stare at them enough. Need a good one next to it.
Re: Interference between torsion bar & tie rod end link [Re: astrobuf] #830499
10/15/10 09:55 PM
10/15/10 09:55 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
The tie rod ends are different. The difference is right hand and left hand threads used to adjust tie rod. The the size of the tie rod end links do not appear any different in size.
I've considered the idler arm and thought about how that may alter the pitman arm's geomerty if it is the wrong one. Will have to investigate further. I was able to compare the centerlink and initially thought it may have been reversed however, that wasn't the case.
Re: Interference between torsion bar & tie rod end link [Re: autoxcuda] #830500
10/15/10 10:02 PM
10/15/10 10:02 PM
ontario canada
426lloyd Offline
426lloyd  Offline
ontario canada
sorry for high jacking again but like I said I have the very same problem with my B body same side every new part is identical to the old part and I highly doubt we both have bent center links .
Re: Interference between torsion bar & tie rod end link [Re: 426lloyd] #830501
10/15/10 10:16 PM
10/15/10 10:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Maybe try installing your old idler then pitman and see if things change.
It has been noted recently in header fitment situations that not all brand idlers put the geometry in the same place. Someone changed brands of idler and headers didn't hit.
Re: Interference between torsion bar & tie rod end link [Re: autoxcuda] #830502
10/15/10 10:29 PM
10/15/10 10:29 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
Wish I had kept it. Unfortunately I got rid of old one when I broke everything down. At the time, it did not occur that I should save in the event that there is a slight difference between the parts. Perhaps it could be the wrong part. I'll have to pick one up tomorrow and go from there.
