Re: Trans Cooler
[Re: DusterKid]
#830460
10/15/10 07:53 PM
10/15/10 07:53 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
Something to consider is the type of cooler. There is the Tube&Fin, which is the most popular because it is the least expensive. The other is what is called a Stack Plate style. In the tube&fin, the oil is routed through a steel tube in a serpentine fashion with the heat transfering to the fins. The stacked plate design routes the oil through small channels and transfering the heat to a series of plates. The big difference is how much surface area the oil comes in contact with and how fast the oil flows through the cooler. You can flow oil through a cooler too fast and not reduce its temperature much. On both accounts the stacked plate cooler is superior but 2 or 3 times the money.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: Trans Cooler
[Re: zzyzxpat]
#830461
10/15/10 09:55 PM
10/15/10 09:55 PM
RapidRobert
largest stack plate one you can fit (not sure what sizes are available but might need to plumb 2 in series). I will defer to Kunkel on this but if the internal cooling fluid passages in/out behind the 2 brass fittings are larger than the brass fitting ID itself then could go to larger fittings and 3/8" lines for more flow (along w a 3/8" cooler of course). Even on a streeter I use the largest surface area I can & I am not convinced a trans can run too cool EDIT but w you being a dragger being too cool is not even an issue
Re: Trans Cooler
[Re: RapidRobert]
#830462
10/15/10 10:14 PM
10/15/10 10:14 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Ferd Exploder's have the stacked plate coolers, many others also I'm sure. Raid the Junk Yard, and put them in a series.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
Re: Trans Cooler
[Re: GO_Fish]
#830463
10/18/10 09:25 PM
10/18/10 09:25 PM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
B&M super cooler
I run 2 coolers. Second one helped tremendously
Why does divorce cost so much?
Because it is worth it!!!!!
