B-body auto vs. Manual tranny X- member #83019
07/02/08 10:29 AM
07/02/08 10:29 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I have a 1970 833 going into my 68 B-body, will the existing tranny x-member work ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: B-body auto vs. Manual tranny X- member [Re: AlexP] #83020
07/02/08 11:03 AM
07/02/08 11:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
for a 70 trans you will use your existing auto trans X member ... the one with the mount hanging off the a member itself
Re: B-body auto vs. Manual tranny X- member [Re: JohnRR] #83021
07/02/08 11:44 AM
07/02/08 11:44 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Its just luck that I happened to come across this trans with a friend of mine. That sure makes the install a little bit cheaper.
As always, thank you John.
