3.0 V6 Question #829479
10/14/10 10:47 AM
10/14/10 10:47 AM
Warminster, Pa.
Slant69 Offline OP
Slant69  Offline OP
Warminster, Pa.
If I remove the alternator from a 3.0V6, 92 LeBaron is the serpentine belt tensioner bolt(s)accessable? Need to replace the tensioner
Re: 3.0 V6 Question [Re: Slant69] #829480
10/14/10 11:22 AM
10/14/10 11:22 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Dunno, BUT there is an engine, either the 3.0 or the 3.3, can't recall which, but it is accessible from rear side of timing cover from underneath vehicle, like I said I can'r remember which of the 2 engines has that rear access.
Re: 3.0 V6 Question [Re: Slant69] #829481
10/14/10 11:29 AM
10/14/10 11:29 AM
NY usa
540challenger Offline
NY usa
Been a while but yes it is accessable /i don't remember uf i did it from up top or through the passengerside wheel well tire removed of course.
Re: 3.0 V6 Question [Re: buildanother] #829482
10/14/10 01:11 PM
10/14/10 01:11 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Its accessable on both the 3.3/3.8 and the 3.0L You will need a 15mm 3/8 drive swivel socket and a long extension accessed from underneith on the back side of engine.
Re: 3.0 V6 Question [Re: Todd] #829483
10/14/10 02:45 PM
10/14/10 02:45 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I always did them from underneath.I use a good swivel impact socket and long extension.Its a pretty cler shot under the car with the extensions.Rocky
Chrysler Firepower
Re: 3.0 V6 Question [Re: Slant69] #829484
10/14/10 03:29 PM
10/14/10 03:29 PM
North Central Indiana
C-Tech Offline
C-Tech  Offline
do not take the Alt off take the air cleaner off and the belt off the nut for the tensioner is on the back side just above the exhaust manifold of #1 cyld you should be able to weasel the tensioner out and replace it.
Kevin
Re: 3.0 V6 Question [Re: therocks] #829485
10/14/10 03:31 PM
10/14/10 03:31 PM
Warminster, Pa.
Slant69 Offline OP
Slant69  Offline OP
Warminster, Pa.
Thanks, guys. I would guess you still have to R&R the alternator even though you're doing it from the bottom.
Re: 3.0 V6 Question [Re: Slant69] #829486
10/14/10 04:08 PM
10/14/10 04:08 PM
C-Tech Offline
C-Tech  Offline
you can get to the tensioner from the top and the alt doesnt have to come off
Kevin
