Need help with power steering 70 challenger #828475
10/12/10 09:09 PM
10/12/10 09:09 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
JUST PUT POWER STEERING BELT ON START UP THE CAR AND THE STEERING WHEEL GOES TO THE RIGHT IS IT THE PUMP OR THE STEERING BOX
Re: Need help with power steering 70 challenger [Re: FOXY312] #828476
10/12/10 09:22 PM
10/12/10 09:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The fluid direction valve is stuck in position,....common for steering boxes that have sat around for a while,.....here's what you need to do,...a little messey, but should solve the problem,...I'll assume you let the car run for awhile and still pulls to one direction?, sometimes the pumps residual pressure will loosen the shift assy, sometimes you have to resort to this....
Re: Need help with power steering 70 challenger [Re: FOXY312] #828477
10/12/10 09:23 PM
10/12/10 09:23 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
possible stuck valve on top of the box
Re: Need help with power steering 70 challenger [Re: AARCONV] #828478
10/13/10 08:55 AM
10/13/10 08:55 AM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
Thank you I hope this works
Re: Need help with power steering 70 challenger [Re: FOXY312] #828479
10/22/10 06:51 AM
10/22/10 06:51 AM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
WELL I TRY THE TOP FORM AND NOW IT WANTS TO GO TO THE DRIVER SIDE, I DID TAKE OFF THE VALVE ON THE TOP OF POWER STEERING BOX AND CHECK TO SEE IF IT WAS STUCK AND CLEAN IT MOVED VERY FREELY INSIDE O-RINGS WERE OK TOO
Re: Need help with power steering 70 challenger [Re: FOXY312] #828480
10/22/10 12:36 PM
10/22/10 12:36 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
QUIT YELLING and try adjusting the valve position to center the wheel like the above diagram depicts..
