Re: MikeyT finally runs the 70 Coronet (Race forum gasps!)
[Re: Dodgem]
#826722
10/14/10 02:30 PM
10/14/10 02:30 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
I did degree the cam in a bit when we put it in the car. I also run a mechanical MSD distributor it is 16 degrees initial with 35 degrees total at 3000 rpms.
Cam is comp cam EX 268 1600 to 5800 advertised durations 268/280 @ 50 224/230 lift:.477/.480 110 LSA
I hope that helps.
Mike
1969 Dodge Dart Swinger
[Re: 68KillerBee]
#826724
10/16/10 09:49 AM
10/16/10 09:49 AM
MikeyT
Watertown, WI
Hey Devin!
Yup, pretty exciting run for sure. Trust me your bee is far nicer.
Mike
[Re: MikeyT]
#826725
10/16/10 11:51 AM
10/16/10 11:51 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I hope that helps.
Mike
I would advance the cam to 104 intake centerline (max lift) and get the advance all in by 1500 to 1800 with lighter advance springs and I'll bet you pick up 4 to 6 tenths.
