NASCAR 1/4 mile time and speed?
#826291
10/10/10 03:49 PM
10/10/10 03:49 PM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Is there any test made what may be NASCAR car quater mile time and speed? Ofcorse they are heavy and with manual tranny but would be interested to know
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
Re: NASCAR 1/4 mile time and speed?
[Re: HotRodDave]
#826293
10/10/10 04:30 PM
10/10/10 04:30 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I think Jeg Coughlin made a pass at Zmax in the Napa car. Low 10s@130ish is what I seem to remember.
68 Barracuda Formula S 340
[Re: Streetwize]
#826295
10/10/10 07:49 PM
10/10/10 07:49 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
The one's I've seen, and I've seen a couple, ran low twelves. I really don't think a NASCAR car out of the trailer could run a ten second time slip.
Don't forget, they are not set up for it. The motors do not make a lot of torque...they do make hp. It's apples and oranges.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: HotRodDave]
#826298
10/10/10 08:12 PM
10/10/10 08:12 PM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
I seem to remmber ther were a couple guys that did that a couple years ago and it seems they were running low 10s
[Re: DodgeCharger]
#826299
10/11/10 09:57 AM
10/11/10 09:57 AM
Georg
Europa, Estonia
thats why I ask. As I know there are no R5/P7 powered drag race car out there? I know there are one turbocharged R5/P7 truck but this is not also for 1/4mile Just want to know or see vid clip from some pure dragrace car ( not dragster ) on 1/4 mile. Here is lot of discussions :"how, I quess etc." but no-one what I heard have been in quater mile in real life. Just that I have now 845hp/555TQ R5/P7 motor and Iam searching light body for that ( around 2400-2500 lbs total weight ) Why I still ask "how much it would run" is that one guy say R5/P7 dont have enough torque for low 9 or even high 8 seconds, second guy says - no problem at all just good converter and correct gear it will fly.... Also guys told to avoid "big rear wheels" and stay with 10.5" slick. But those two rollers what Iam watching right now is with narrowed rear end and with "big slick" ( 32/16-R15 )
Premium Performance
[Re: Georg]
#826300
10/11/10 11:01 AM
10/11/10 11:01 AM
Posts: 1,019 Finland
mafo
Finland
You have to remember that your tracks are nowhere as good as in the US, maybe you don t need 16 inch slicks but 10.5 are to small for you a small low torque motor need to be launched hard, you can t do that with small tires on a lousy track
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: Georg]
#826301
10/11/10 11:11 AM
10/11/10 11:11 AM
DodgeCharger
Mohnton, Pa
If you have 845 hp with a 2400-2500 # race car all you need is the right converter and gear and you should make it into the 8's. I also agree you will need a big tire to hook.
[Re: DodgeCharger]
#826302
10/11/10 11:59 AM
10/11/10 11:59 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Right converter and gears and it will go just as fast as an equal HP big motor. You just have to keep it in it's power band. HP is HP you just have to multiply it with gearing to get the TQ at the wheels and TQ at the wheels is all that matters An over the road diesel from an 18 wheeler might make 1000 ft lbs TQ and 300hp but still would not be any faster than a 300hp gas motor in an equal weight dragster if both combos were optimised.
[Re: HotRodDave]
#826304
10/11/10 12:35 PM
10/11/10 12:35 PM
Steve1118
Those cup motors do not work well for drag racing. If you notice, you can find them on ebay pretty cheap, around 7g. There are guys who've tried to make them work in comp eliminator, in dragsters and altereds, and they have given up. They've tried different camshaft profiles, converters, etc, but the design just does not lend itself well to the drag strip. The reason you can buy them cheap is that they are for one application only.
It takes more than horsepower to drag race. Those motors have a real short stroke, short deck, and make no torque or mid range power. They make 800+ power at 8500 rpm, but you don't run a drag car 8500 rpm beginning to end. The torque and mid range is equally important.
It's just a matter of application. Those motors are built for what they do, and they do it well. They run wide open for long periods, and make good power. But, they do not lend themselves for drag racing.
[Re: Steve1118]
#826305
10/11/10 01:58 PM
10/11/10 01:58 PM
Georg
Europa, Estonia
thats what I was talkeing about. Last poster Steve hammer this motor to ground, other guys says its best motor for this price to get and can easely drive you sure into deep 9 seconds... what to belive?
Premium Performance
[Re: Georg]
#826306
10/11/10 02:23 PM
10/11/10 02:23 PM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
Thought there was already someone on this board that had a P7 motor in a dart that was going in the 9's, IIRC.
LBSR
[Re: Georg]
#826307
10/11/10 02:29 PM
10/11/10 02:29 PM
Steve1118
I'm not hammering it into the ground....I'm just stating facts. Those cup motors are specifically designed and built for wide open laps around a super speedway for extended periods. That's is the reason for their existence.....that is why you can by them very reasonable. The market for a used one is very limited.
[Re: Steve1118]
#826308
10/11/10 02:40 PM
10/11/10 02:40 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
ScottB went a 9.41 in his Dart "IIRC" at Norwalk with a 1.29 60 ft his car is at least 3,000 lbs. with him in it. not bad for a restricter plate motor untuned i think the mph was 143
