Re: Cam phasing vs. intake reversion [Re: HEMIFRED] #825554
10/10/10 12:58 AM
10/10/10 12:58 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
now here's a chart to follow use only the red path unless it's past 5pm and you are using 89 pmup.
otherwise the black and race gas
Looks like my daughter got hold of that one w/ a box of Crayons.
I should have mentioned that the reversion I'm talking about is the dilution of the intake charge during overlap when the burnt exhaust gets pushed back up the intake tract after the intake opens, not the effect of the intake valve being left open too long.
As Brian H. mentioned, being a street-driven car there may be no way to really eliminate the issue which (I'm assuming) is happening during low(er) RPM part-throttle operation. The deposits weren't showing up as far back as the intake manifold, but were concentrated above the valve and into the bowl entrance.
Perhaps I should pour a can of BG 44K in the 'Pig once in a while...
Re: Cam phasing vs. intake reversion [Re: HEMIFRED] #825555
10/10/10 05:51 AM
10/10/10 05:51 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Fred, It looks to you were using 100 proof when you made that graph, lol.
8.30's @3400 lbs
Re: Cam phasing vs. intake reversion [Re: BradH] #825556
10/10/10 05:59 AM
10/10/10 05:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
wider LSA to reduce overlap.
Re: Cam phasing vs. intake reversion [Re: Mike Swann] #825557
10/10/10 06:27 AM
10/10/10 06:27 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
it looks much clearer when you include the use of the yellow lines suggested by the beer stops along the way
home of the
Sox and Martin Hemi Duster
