Page 2 of 3 1 2 3
Re: Lakewood Traction Bars [Re: slantzilla] #824928
10/09/10 08:17 PM
10/09/10 08:17 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
sounds right...my Dart has good ole ESPO springs with the traction bars. The bars were supposed to be for fun, but heck, they worked.
Duster has SS springs, no traction aids.
Re: Lakewood Traction Bars [Re: dustergirl340] #824929
10/10/10 01:24 AM
10/10/10 01:24 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
still have mine on...
Re: Lakewood Traction Bars [Re: AARCONV] #824930
10/10/10 01:34 AM
10/10/10 01:34 AM
Southwest, Mi.
74Cuda Offline
74Cuda  Offline
Southwest, Mi.
You want to run as far as you can from traction bars on a car and get a longer pinion snubber over the rear u-joint.
I tried these bars back in the 70's on my Cuda and it was I was driving on water all of the time. No traction but with the snubber traction was great.
Re: Lakewood Traction Bars [Re: AARCONV] #824931
10/10/10 02:15 AM
10/10/10 02:15 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
I have mine on too. They work and I have always thought they looked cool.
Re: Lakewood Traction Bars [Re: keith airgrabber] #824932
10/10/10 02:31 AM
10/10/10 02:31 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
The only reason why I haven't put them on is due to clearance issues with the road, pulling into parking lots, bumps in the road, you get the idea... CRUNCH!!!
Re: Lakewood Traction Bars [Re: slantzilla] #824933
10/10/10 08:16 AM
10/10/10 08:16 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Ran them on my Dart just for fun (got them in a trade) and my sixty foot dropped. Most Mopar guys just automatically dismiss them because they heard from someone that they don't work, I prefer real world trial and error instead of hearsay.
I'm a firm believer in the "if it works then it works" philosophy (so is Yogi Beara), BUT I'm curious as to why thesuperstock guys/Ramchargers always used snubers instead and all the MP books state not to use tractions bar, only snubbers?
Probably because they ran SS springs. Traction aids are not supposed to be used with them other than a snubber.
Showing my age a bit here. I think the SS springs came out with the 68 Cuda and Dart. Later it all went link bars. I was wondering what they did pre 68. Was it trac bars, snubber or nothing?
Re: Lakewood Traction Bars [Re: keith airgrabber] #824934
10/10/10 08:45 AM
10/10/10 08:45 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm sorry but I always thought they looked dorky. Look how low to the ground yours are. lol Plus a pinion snubber weighs alot less.
Re: Lakewood Traction Bars [Re: Challenger 1] #824935
10/10/10 09:33 AM
10/10/10 09:33 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
you dont think the front springmounts ataching to what litle frame is available under these cars would be a better place to direct all the rotational forces from the rear axle compared to putting all that force straight up into the much thinner floor?
Re: Lakewood Traction Bars [Re: 1Fast340] #824936
10/10/10 10:35 AM
10/10/10 10:35 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Someone must know what the Mopar engineers had in mind when they specified the snubber and said not to use the trac bars. I know we are killing this topic but I'm a sucker for these two sided arguments. I'll see what I can dig up from my old books.
Re: Lakewood Traction Bars [Re: torkrules] #824937
10/10/10 12:55 PM
10/10/10 12:55 PM
Southwest, Mi.
74Cuda Offline
74Cuda  Offline
Southwest, Mi.
Traction bars are for GM cars and pinion snubbers are for mopars.
I never had a GM get me of the line so I believe that Mopar engineers know what they are doing.
Re: Lakewood Traction Bars [Re: Challenger 1] #824938
10/10/10 01:20 PM
10/10/10 01:20 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
I know...it's GREAT. Guys see ours and think we don't know anything. Their attitude gets all condescending...ROFL
Re: Lakewood Traction Bars [Re: torkrules] #824939
10/10/10 01:21 PM
10/10/10 01:21 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
yep its intresting when looking at stuff deeper than just saying "this is the way it is because thats how it has been done foreverer"
only real good reasons i can see is that it would help keeping the axletubes from twisting in the centersection, it would also help in alowing the rear suspension to still work side to side so to speak,while tractionbars should be able to lessen boddy roll when under full power, but im not an engineer:)
would be very intresting if you found any deeper info on this
Re: Lakewood Traction Bars [Re: 1Fast340] #824940
10/10/10 02:29 PM
10/10/10 02:29 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Ok, according to Larry Shepherd and the old Direct Connection book (see that's how old I am), he says, traction bars are not recommended. So there not saying "DO NOT USE THEM". The reason stated is that they may cause the axle tubes to bend or undesirable handling. They should NOT be used with super stock springs (goes without saying).
Not sure how they would bend the axle tubes other than the fact they are outboard, but I would think Fords and GMs would have the same problems. As far as ill handling, well superstock springs can do that for you too.
The snubber is optional on the automatic but should be used for safety. They say it's a must on 4 speed cars. They recommend re-enforcing the floor.
Re: Lakewood Traction Bars [Re: torkrules] #824941
10/10/10 02:50 PM
10/10/10 02:50 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
good info there
problem with the axletubes are probably from the fact that the pinion want to climb the ringgear and that its more sensible to stop this motion by having a snubber stop the movement upwards compared to having the tractionbars holding the tubes from rotatatin while the front of the centersection wants to go up, this also explains why cars with a torque arm hooks so well once everything is right
Re: Lakewood Traction Bars [Re: torkrules] #824942
10/10/10 03:17 PM
10/10/10 03:17 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
How well traction bars work is directly related to the amount of thought and effort in tuning them. Just slapping a pair on is only the first step. Clamping or unclamping the springs and trimming the snubbers to set preload must also be done for them to work well. But at least you can set preload from side to side to prevent the torque from trying to pick up the passenger side tire, which helps traction and helps keep the car in a straight line. If you can tell me how to preload one side with a pinion snubber, I'm listening. That is, how without using SS springs that are mismatched from side to side, ride unnecessarily hard, and affect normal handling.
Leaf springs by nature aren't suited to transmit torque - by the time they are stiff enough not to wrap up they are way too stiff to let the back work. A softer spring package with properly tuned slapper bars can work extremely well with a little tuning. And no, I didn't forget about shocks; that's a whole other topic.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Lakewood Traction Bars [Re: 1Fast340] #824943
10/10/10 03:18 PM
10/10/10 03:18 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
Has anyone ever really bent an axle tube on a street car? I'd say for most cars, they are a good way to control spring wrap or wheel hop.
The Blue Goose
My instagram: Bossride
Re: Lakewood Traction Bars [Re: BossRide] #824944
10/10/10 03:47 PM
10/10/10 03:47 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i seem to remember a sertain blue finnish vip that broke the tubes loose from the housing, it is a streetcar but alitle over the normal.
Re: Lakewood Traction Bars [Re: 1Fast340] #824945
10/10/10 03:56 PM
10/10/10 03:56 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
Are the axle tubes pressed in like an 8.8" Ford? If so, can you weld them to the housing?
The Blue Goose
Re: Lakewood Traction Bars [Re: BossRide] #824946
10/10/10 04:11 PM
10/10/10 04:11 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
8 3/4 have stamped steel housings where the tube is part of the assembly. The 7 1/4, 8 1/4, 9 1/4, and Danas have pressed in tubes that can be welded for more strength.
Re: Lakewood Traction Bars [Re: Evil Spirit] #824947
10/10/10 06:00 PM
10/10/10 06:00 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
Ahhh.. I just got an 8 3/4... didn't really pay attention to the differences...
The Blue Goose
Page 2 of 3 1 2 3
