Hi!
When you restore an engine and want to retain the factory look....what do you do about the damper?
I am afraid of using an old damper on a brand new engine build.
Specifically I want to do with my 69 HEMI engine rebuild and my 71 440-6 rebuild, both of which are numbers matching engines.
I dont trust the old original dampers even if the "look good".
Does somebody offer a "damper rebuild service"?
And if so, how good a work do they do?
Also, is anybody reproducing the HEMI and 440-6 dampers? And if so, are they good quality?
I was about to just forget about the dampers and put a couple GOOD dampers on those engines like ATIs and just paint em over. I know that originality on these cars is the ticket, but in occasions like this I think Im gonna say "screw that"!!!
