Door key lock problem? #823565
10/06/10 08:01 PM
10/06/10 08:01 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I just discovered that apparently the ignition switch was changed on my 1964 Fury not long before I got it. The key that came with the switch works the switch just fine, but has no effect on the door locks. That key (and the trunk key) are all that I got with the car, and now the previous owner is long gone.
Can I do anything with the door or ignition locks to get the key to work on both? Or will I just have to get new door locks and carry two keys, and if true, where to get new door locks? Thanks!
Re: Door key lock problem? [Re: polkat] #823566
10/06/10 08:09 PM
10/06/10 08:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Remove the door locks & take them to a locksmith, he can re-key them to match your ignition key.
Re: Door key lock problem? [Re: Alaskan_TA] #823567
10/06/10 09:44 PM
10/06/10 09:44 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I've read that it is not that difficult to recode your cylinder locks (and cheaper then a locksmith). Just a matter of swapping pins around. Anyone know about it? Thanks!
Re: Door key lock problem? [Re: polkat] #823568
10/06/10 10:06 PM
10/06/10 10:06 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
You may need special key blanks and pins to work in a 64..
Mopar changed vendors in 68 from Yale to Briggs and Stratton..
The key milling and pins do not interchange backwards from 69...
Re: Door key lock problem? [Re: sthemi] #823569
10/06/10 10:31 PM
10/06/10 10:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The earlier door locks are a real PITA according to my locksmith, and parts aren't available. Be careful if you buy a set, prices are all over the map. Bought a supposed NOS matched set from a place called Jesser's ($245!!) that were in fact not NOS and they fell apart.
Re: Door key lock problem? [Re: polkat] #823570
10/07/10 01:53 PM
10/07/10 01:53 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
1962 to 1965 door locks are a PITA to rekey. Plus the pins are different sizes that the 1966 and later locks. Most of the rekey kits have the later pins.
However I do rekey the early locks frequently. Send me a PM if you want them done.
