Are 59 Imperial door/window seals available? #819932
10/02/10 12:47 PM
10/02/10 12:47 PM
Kirkland, Washington
Pacnorthcuda Offline OP
I have a neighbor that has a 59 Imperial Crown Royale. Says he's been looking for the door/window rubber seals for years. Not available.
Anyone know if thats true?
Re: Are 59 Imperial door/window seals available? [Re: Pacnorthcuda] #819933
10/02/10 03:37 PM
10/02/10 03:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I suspect he's right about no model specific parts but he probably can buy the extruded weatherstrip material that comprises 95% of his weatherstrips & then try to save the special molded corners & such off his original parts... Not a perfect solution but one that does work quite well for most guys..
BTW try contacting Steele Rubber for the extruded bulk seal material..
Re: Are 59 Imperial door/window seals available? [Re: 1_WILD_RT] #819934
10/03/10 01:00 PM
10/03/10 01:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Try restorationspecialties.com for them; pretty sure they have at least the bulk stock and could make them from samples if not from info they have.
Re: Are 59 Imperial door/window seals available? [Re: Pacnorthcuda] #819935
10/03/10 06:17 PM
10/03/10 06:17 PM
Joliet, IL Area
tranch Offline
tranch  Offline
Joliet, IL Area
Try here. They do have some 59 Chrysler weather stripping.
http://www.oldmoparts.com/a.htm
