Re: 361 same as 383 and 400 ?
[Re: 440newport]
#81981
06/30/08 10:42 AM
06/30/08 10:42 AM
except that the last year for the eight-bolt extended-flange crank was 61. 62's switched from cast iron to aluminum torqueflite and used what we now think of as the "normal" six-bolt standard-flange crank.
[Re: Mopar_Mike]
#81986
07/02/08 05:01 PM
07/02/08 05:01 PM
Posts: 4,588 St. John's Newfoundland
440newport
the 361 lasted until atleast 1965
1966 last year for the 361.
If you want to get picky the 361-3 was used in industrial and truck applications into the 70's. '66 was the last year for pass. car use which is what I meant to say in my first post.
And 413coronet, I keep making that mistake...for some reason I always think '62 was the cutoff year even though I know it's '61.
[Re: 440newport]
#81987
07/02/08 05:27 PM
07/02/08 05:27 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
[Re: MoparJ]
#81988
07/02/08 07:51 PM
07/02/08 07:51 PM
361/383/400's all have different casting #'s, therefore they are different blocks. however the main difference is only the bore sizes.
