Page 5 of 13 1 2 3 4 5 6 7 12 13
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: ademon] #819714
10/03/10 02:31 PM
10/03/10 02:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I smell a 4.5 crank some more cam, bigger valves mabey some more compression comeing for the hemi
But it will sound less stock
Don't have to sound less stock, the extra cubes and compression will help make the cam seem milder
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: B5 Bee] #819715
10/03/10 02:32 PM
10/03/10 02:32 PM
N of Detroit
DaveDudek Offline
DaveDudek  Offline
N of Detroit
The RoadRunner is a 496.
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: B5 Bee] #819716
10/03/10 02:32 PM
10/03/10 02:32 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I know this wouldn't be a popular move, but to keep the cars stock appearing and to avoid the cost to comply with 9.99-quicker safety requirements, any thoughts to changing the rules to slow the cars down, such as no more roller cams and limit motors to 514".
That would require much more tech and a P&G meter
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: DaveDudek] #819717
10/03/10 02:35 PM
10/03/10 02:35 PM
NY
aarmaniac Offline
aarmaniac  Offline
NY
Congrats to Lane and Dave for breaking the 9 second barrier. First video is Lane's 9.92 second is Dave's 9.98. Notice Dave's brake lights are on before the end of the 1/4 mile. He can tell you why.
Lane
http://www.youtube.com/watch?v=aNzU0IwtvFo
http://www.youtube.com/watch?v=sK5Z0VH_cEQ
F.A.S.T. Legal AAR Cuda 11.57 @ 118 mph 1.72 60"
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: ademon] #819718
10/03/10 02:37 PM
10/03/10 02:37 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Cubes and compression smooth out an idle......
Congrats on your 9 second run Dave.......
BTW.......I JUST got off the phone with Lane and, MAN, was he excited.......said he was screaming at the top of his lungs when he got the 9 sec. time slip.....
I met him in '05 and he's a great guy that's spent a LOT of time and, I'm sure, quite a bit of money to get that car to where it's at....... He said he knew the car had a 9 in it this spring but was having traction issues and finally figured it out before this race....... said it never even tried to spin the tires and the track was good, but not stellar.....
If you can't handle the truth, you're living a lie.......
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: Big Squeeze] #819719
10/03/10 02:42 PM
10/03/10 02:42 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mustang should idle like a 318 at 588ci
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: Big Squeeze] #819720
10/03/10 02:49 PM
10/03/10 02:49 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
if i had to guess..hypothosis..
he's got more than enough power now...
Dave prolly has a little room with less studder/retard out of the hole...to get a quicker 60ft and et...as the car is currently running..
seems..a tad - creap in that direction(apply more power)...will be the biggest improvement in et the as it is right now....
"seems that track may have held it this past weekend....?"
that would be my guess....
Traction finding it..clutch,fuel or retard/power abatement...at the launch
Nailing how hard you can leave/apply power and what the track will hold on any given pass..
its the ubiquitous dilema for cars that make passes on the razors edge...
its a gamble..if you think your apponent is gonna go after too much and spin...
you may decide not to push/change your combo.
i have no doubt Dave the Dude knows what he is doing...
killer job..Dude!!!!!
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: DaveDudek] #819721
10/03/10 04:05 PM
10/03/10 04:05 PM
Canada
CrAzYMoPaRGuY Offline
Canada
All the MORE impressive I say.
I love the performance of Lane's car, and it's impressive for sure, but yours Dave truly impresses me most.
I guess I'm biased.
Keep up the good work!
CrAzYMoPaRGuY
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: CrAzYMoPaRGuY] #819722
10/03/10 07:09 PM
10/03/10 07:09 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
I guess I'm biased.
Something else to think about......Lane said his motor is out of carburetor at 6,600RPM.... but crosses the finish line WELL over 7K.......
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: Big Squeeze] #819723
10/04/10 12:19 AM
10/04/10 12:19 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A big plenum can make up somewhat for a small carb, mabey he figured out a way to get a huge plenum under the carb
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: Hemi Allstate] #819724
10/04/10 01:55 AM
10/04/10 01:55 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Wow, congrats to all. Amazing track. Amazing times.. You guys all had one heck of a banner year.. FYI, here is the info on the Mustang.
CID 500+
Compression 12.2 to 1
Carb Holley 750 Vac Sec
Camshaft 60mm
Rocker Arms WW Shaft Rockers
Crankshaft Crower
Connecting Rods Aluminum
Ignition MSD digital 7
Heads DOOE-R Cast Iron
Exhaust manifolds OEM
Transmission C4 Automatic
Torque Convertor 2200 stall, 9.5"
Rear Gear Ratio 4.11
Tires G60x15 polyglas
Wheels Magnum 500's
Weight 3742 [/quote
So a 9.84 @ 139.8 with 3742 lbs. according to Wallace is
Your HP computed from your vehicle ET is 698.63 rear wheel HP and 776.26 flywheel HP.
Your HP computed from your vehicle MPH is 705.94 rear wheel HP and 784.38 flywheel HP.
According to Lane, those specs are the old motor.
the motor is 14.7 with a C&S carb. AND YES the intake is a cast iron SCJ with extensive work. She made just over 825 hp @6200 and just over 800 lbs with iron exhaust manifolds and idles @ 900rpm all through 2 1/2 inch dual exhaust with mufflers. I'm pretty sure there's another 2 tenths when i get it all sorted. She went 1.523 60 on G60-15 polyglass tires, NO traction devices at all. Split mono leafs with stock suspension. Only adjustable front and rear shocks.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: BBR] #819725
10/04/10 07:44 AM
10/04/10 07:44 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
"The RoadRunner is a 496."
"(LANE claims 588 cubes)"
Whoa!!! Giving up 92 cubic inches and only 0.15 behind in et?!
This post is available in double vision where drunk.
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: bwdst6] #819726
10/04/10 09:01 AM
10/04/10 09:01 AM
an8sec70cuda Offline
Congrats to Dave and Lane! Those are awesome times from cars that look like they do, not to mention on those tires!
If I had a car similar to that, I'd be cleaning up at the local tracks w/ money runs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: an8sec70cuda] #819727
10/04/10 09:04 AM
10/04/10 09:04 AM
NC USA
U
ultimatelenny Offline
U
NC USA
Congratulations to Lane on your outstanding weekend, truly impressive. Also kudos to Ed Cook and son on your great outings!!
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: ultimatelenny] #819728
10/04/10 09:29 AM
10/04/10 09:29 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
The tires these guys run in this class are an accident waiting to happen. Why they continue to run those tires is crazy, someone is going to get hurt bad.
logan426
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: MLR426] #819729
10/04/10 09:41 AM
10/04/10 09:41 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Congrats to all F.A.S.T guys on their impressive runs.......but, if a BES 588ci with almost 15-1 squeeze is accurate, the Roadrunner is severly outgunned at the moment. Aftermarket suspension parts to keep the Mustang safe & straight not-withstanding.
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: bwdst6] #819730
10/04/10 09:44 AM
10/04/10 09:44 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Yeah, it looks like the Hemi's two carbs, better intake, better exhaust manifolds and, I'm assuming, cylinder head flow advantage makes it pretty even (both are running very similar MPH's ).......
Wonder what both cars weigh?
I've never heard of a factory bias ply tire coming apart, even back in the day, especially when they're less than a few years old, like these guys are running them.......
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: Big Squeeze] #819731
10/04/10 09:55 AM
10/04/10 09:55 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Wonder what both car weigh?
Wayne, you beat me to it.
The Hemi has more advantages than any other entry in terms of factory parts. Hands down. And you aren't stuck trying to make 40 and 50 year old parts work in this type of environment. You have the luxury of using new stuff if you wish.
For those that think that bigger is better, consider this. The two Cook A12 cars went as follows.
493"-stick car went a best of [Email]10.81@129.[/Email]
526"- auto car went a best of [Email]10.73@128.[/Email]
The 526" is a more sophisticated build in a lighter car with an automatic.
Not so sure that the extra cubes is the whole answer, especially with a flow limuted head like the 906 and the traction issues of the bias ply redlines.
MB
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: Big Squeeze] #819732
10/04/10 10:15 AM
10/04/10 10:15 AM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
No replacement.. displacement, yada, yada, yada. When it comes to efficiently producing HP I've never seen figures given in HP/CFM. Now I've seen a lot of figures on many engines in terms of HP/CI!!!
I would guess the RR would be at least 3800 being all steal so it's probably giving up some there, too.
Re: 10.02 @ 139.02 ... the black Road Runner goes FASTer [Re: HPMike] #819733
10/04/10 10:15 AM
10/04/10 10:15 AM
Trumbull,CT.
Trumbull,CT.
Let BES take 100 cubes out of that engine and lets see how it runs.
Better yet.....lets see it be 100ci SMALLER than Dudek and lets see how it runs.
