Hughes 'OEM replacement' cam for 383-440 HP / 6BBL
#817486
09/29/10 03:58 PM
09/29/10 03:58 PM
BradH
Hughes doesn't really offer an OEM replacement cam, but IMO this would be it. If anyone is looking for a modern version of the OEM 383-440 HP / 6BBL cam grind, Hughes has something in their Clearance section that would fit the bill: 215/223 @ .050", .470"/.506", 115 LSA, 3-bolt, $125 (Clearance price) Compared to the OEM cam's 214/226 @ .050", .450"/.458", 115 LSA, it'll probably idle the same and pick up the torque across the curve. I wouldn't expect it to change the working RPM range much, though. http://www.hughesengines.com/Index/produ...mp;partid=26158If I still had my A12 RR, I'd grab this myself. Since I don't, I figured the next best thing is to give somebody else a "heads up" about it.
Re: Hughes 'OEM replacement' cam for 383-440 HP / 6BBL
[Re: JohnRR]
#817488
09/29/10 04:09 PM
09/29/10 04:09 PM
BradH
470./506 ??? that's quite the lift on the exhaust, assume that would be a good cam for exh manifolds ?
Yep, that's part of why I think it would be a good choice.
The OEM ramps are also reeeealy slow and the Hughes grind "should" increase the cranking pressure a tad installed on the same ICL as stock.
[Re: RoadRunnerJD]
#817490
09/29/10 07:54 PM
09/29/10 07:54 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Hi Brad! Long time no hear!
I thought they had him locked uo somewhere.
[Re: 62maxwgn]
#817491
09/29/10 07:59 PM
09/29/10 07:59 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
Once a racer ALWAYS a racer.....take a look at his posting history
Brad, thanks for the heads up on the cam.
MikeR
[Re: A12]
#817492
09/29/10 11:16 PM
09/29/10 11:16 PM
BradH
Yeah, I was locked up in the Insane Asylum for having been crazy not to realize I'd run my Challenger's engine low on oil due to an undetected leak from the pan.
So... it's back apart (AGAIN) waiting for the time to reassemble it now that the machine work to the block & heads has been completed.
(right type of car, wrong color)
[Re: BradH]
#817496
10/07/10 03:37 PM
10/07/10 03:37 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Somebody (besides me) should buy this cam...
You talking to me?
[Re: RoadRunnerJD]
#817498
10/07/10 10:48 PM
10/07/10 10:48 PM
BradH
You talking to me?
If you still have those Comp 911 springs, then you're half way there. The cam that I remember you running in the RR was too freakin' big for exhaust manifolds anyway, IMO.
[Re: BradH]
#817499
10/07/10 11:40 PM
10/07/10 11:40 PM
RoadRunnerJD
Warrenton, VA
You talking to me?
Yes, but it sure sounds good!
