what will it run 418 stroker?UPDATED RESULTS!! #816776
09/28/10 05:48 PM
09/28/10 05:48 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
88 dakota 3340# street/strip
weight bias is 56%front,44%rear
340 stroker 418cid, 9.7 compression
ohio 4" crankshaft,scat i-beam rods, diamond pistons(balanced).cam is solid roller herbert .246/.254@.050,.585in/.600 ex,lash set at .018in/.020ex,108 lobe seperation, installed at 103.5*.
cast x-heads full port/polish, w/manley 2.055/1.625,db springs to match the cam [Email]etc.flowed.270@.600in[/Email],.170ex@.600
weiand x-celerator intake gasket matched
harlans sharp 1.5 rockers/shafts/holddowns
manley pushrods
stock, rebuilt holley 750 db pumper 6.5 pv, jets are 73f/81r,squirters are 31/31.
msd 6al box,mp distributor
tranny is 727 with reverse pattern,low band apply good clutches/kolenes ,ptc 10" converter flashes 4100 rpm,
8 3/4 rear sure-grip with 3.91 gears.
295/65-15 mickey thompson drag radial
stock shocks front/rear
caltrac style bars heim joint ends
truck has been a best of [Email]7.54@90[/Email] mph with 1.63 60ft, with a mild 318 and a shot of nitrous.any ideas were i might be when i get it tuned in?also what rpm should i shift at?im heading to the track this friday night.thanks mike
Re: what will it run 418 stroker ?1/8 mile [Re: hp340nos] #816777
09/28/10 06:02 PM
09/28/10 06:02 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
11.60 1/4 , not sure on 1/8
Re: what will it run 418 stroker ?1/8 mile [Re: hp340nos] #816778
09/28/10 06:23 PM
09/28/10 06:23 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I had a similar combo years ago and found through testing that a bigger carb netted better et's. I went from a 750 to 950hp.
I went 11.20@ 119 in a 3500 lbs Challenger so I would guess you would run similar to that, maybe a touch slower because of your gearing.
It sure run well though!
Re: what will it run 418 stroker ?1/8 mile [Re: TheOtherDodge] #816779
09/28/10 06:26 PM
09/28/10 06:26 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
6.90s/80s.
Re: what will it run 418 stroker ?1/8 mile [Re: TheOtherDodge] #816780
09/28/10 06:31 PM
09/28/10 06:31 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
My dart had a very similar setup, but with ported w2's and a flat tappet cam. It ran 7.30s in the 1/8 at 95mph, and 11.30s in the 1/4 at 118.
Re: what will it run 418 stroker ?1/8 mile [Re: 340_Dart] #816781
09/28/10 08:00 PM
09/28/10 08:00 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
7.35 no bottle
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: what will it run 418 stroker ?1/8 mile [Re: FlyFish] #816782
09/28/10 08:04 PM
09/28/10 08:04 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
7.40 with the 750. 7.20's with a 950 jetted right.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: what will it run 418 stroker ?1/8 mile [Re: ChrgrCuda] #816783
09/28/10 08:13 PM
09/28/10 08:13 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
It better be making more than 500hp considering the cam/head flow.
If it does, it should run 7.00 and possibly into the 6's as long as your 60's pick up into the 1.4 range.
MPH should be in the high 90's, 98-99ish.
Re: what will it run 418 stroker ?1/8 mile [Re: RobX4406] #816784
09/28/10 09:47 PM
09/28/10 09:47 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Mike,
Im thinking a 7.10/ 7.oh if you get it to hook. what time are you going to be there? We could always try out my 6 pack set up on it. Maybe I will see you there...Phill
Re: what will it run 418 stroker ?1/8 mile [Re: 9 Sec Phill] #816785
09/28/10 10:10 PM
09/28/10 10:10 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Those heads are going to be the problem...
Re: what will it run 418 stroker ?1/8 mile [Re: DaKuda] #816786
09/28/10 10:39 PM
09/28/10 10:39 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i would be happy with anything in the 7,s,i dont know what rpm to launch at or shift at, thats why im doing this test/tune,should be fun, has alot more power than the old tired 318 i had in there,phil i will be at the track at 5:00 or so,dakuda what is the problem with the heads?
Re: what will it run 418 stroker ?1/8 mile [Re: hp340nos] #816787
09/28/10 10:51 PM
09/28/10 10:51 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Nothing "wrong". I tried a set ported and stock. I thought they were running good then put a set of box stock Eddys on and was blown away how much better they ran with no work. I just think that stroke will want a better head. Still will be a great/fun engine. Save your money and run what you have for now.
Re: what will it run 418 stroker ?1/8 mile [Re: DaKuda] #816788
09/28/10 10:52 PM
09/28/10 10:52 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
By the way, when you have some extra money....RPM AirGap. You will be amazed!
Re: what will it run 418 stroker ?1/8 mile [Re: DaKuda] #816789
09/30/10 12:40 AM
09/30/10 12:40 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thanks for all the guesses guys, i will update this with my times after friday night test/tune.thanks mike
Re: what will it run 418 stroker ?1/8 mile [Re: hp340nos] #816790
09/30/10 12:50 AM
09/30/10 12:50 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
needs more gear for eigth mile.
i assume its street driven..?
with a 430 gear id say 680s
i am gonna say 7.0 as it its.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: what will it run 418 stroker ?1/8 mile [Re: hp340nos] #816791
09/30/10 01:36 AM
09/30/10 01:36 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'll say 7 teens sorted out, it will need more carb IMHO. Don't let anyone fool you, the X-Celerator is a good intake. I went 7.20s in a 3240# Dart with a stock stroke 340 on pump gas with a hydraulic cam. The 3.91 gears will be fine, your motor should be a torque monster. I'd shift it around 5800- 6000 rpms if it were mine.
Re: what will it run 418 stroker ?1/8 mile [Re: justinp61] #816792
09/30/10 09:28 AM
09/30/10 09:28 AM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
4.30 gers ran ok in my old 416 cuda but the 3.91 gears ran faster with a qwuiker ET. about a tenth and a couple MPH...Phill
Re: what will it run 418 stroker ?1/8 mile [Re: 9 Sec Phill] #816793
09/30/10 09:36 AM
09/30/10 09:36 AM
GA
Boosted Offline
Boosted  Offline
GA
7.25 tuned.. Off the trailer 7.50's
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: what will it run 418 stroker ?1/8 mile [Re: Boosted] #816794
09/30/10 02:15 PM
09/30/10 02:15 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
no trailer, this truck is street driven to the track about 35 miles.hopefully the weather holds out friday,heavy rains here today in ny.
Re: what will it run 418 stroker ?1/8 mile [Re: hp340nos] #816795
10/01/10 10:55 PM
10/01/10 10:55 PM
ohio
all spooled up Offline
ohio
6.96 at 99 mph
