73 challenger headliner install #816619
09/28/10 10:11 AM
09/28/10 10:11 AM
Omaha
road Offline OP
road  Offline OP
Omaha
Before the headliner is installed, are there are any pieces for the seat belts etc. that need to be installed prior to the install.
I have put the screws in place where the visors go and the dome light.
Re: 73 challenger headliner install [Re: road] #816620
09/28/10 10:24 AM
09/28/10 10:24 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There are four brackets(two per side) for the shoulder belts that are under the top. The clips that hold the belts up on the roof screw to those brackets under the top.
You can also install the screws for the coat hooks if you havn't done that.
Did you go with the perforated style headliner or get the factory style?
