Resto battery 'tops'
#816528
09/28/10 05:20 AM
09/28/10 05:20 AM
Posts: 123 Gold Coast, Australia.
6pacdave
Hi guys, Are there any red top battery moulded 'covers' avail for perf Mopars. Eg to cover the top of an existing battery to give the resto look?
cheers Dave
70 GTX
70 Chevelle SS396
69 Mustang F'back
Re: Resto battery 'tops'
[Re: 6pacdave]
#816529
09/28/10 09:01 AM
09/28/10 09:01 AM
Posts: 553 DE
Ply72rr
DE
[Re: Ply72rr]
#816531
09/28/10 09:50 AM
09/28/10 09:50 AM
6pacdave
Oh crap! So the resto battery's are OK with the bracket?.
cheers Dave
70 GTX
70 Chevelle SS396
69 Mustang F'back
[Re: burdar]
#816532
09/28/10 10:10 AM
09/28/10 10:10 AM
Posts: 21,506 N.E. OHIO, USA
A12
N.E. OHIO, USA
It's been posted here before that the covers are a lot wider than a stock battery. Your stock battery hold down brackets will NOT fit over the cover.
NOT without a little tweaking but it CAN be made to fit. You will need to straighten the top rod a little that "Z"'s across the cover (topper) and then tweak the side clamps just a little and it will work fine. I had problems finding a group 24 battery that was fairly flat on the top (needed for the topper to fit correctly) at the big national chain auto parts stores but found one at Tractor Supply Co. Worked fine until I got a repo Mopar group 27 battery.......but then that's a nightmare story for another time.
MikeR
[Re: A12]
#816534
09/28/10 11:24 AM
09/28/10 11:24 AM
BradH
NOT without a little tweaking but it CAN be made to fit...
For example...
[Re: BradH]
#816535
09/28/10 12:19 PM
09/28/10 12:19 PM
A12
N.E. OHIO, USA
For example...
Nice Brad
For example II...
(but as noted these are both "Z" type hold downs)
MikeR
[Re: A12]
#816536
09/28/10 05:46 PM
09/28/10 05:46 PM
6pacdave
They definately look the part. Did any of you guys use the post extentions with the application?
cheers Dave
[Re: 6pacdave]
#816537
09/28/10 07:08 PM
09/28/10 07:08 PM
A12
N.E. OHIO, USA
cheers Dave
I didn't have to use any extensions on the battery posts but that's because I was able to find a battery with a flat top like this:
not like this:
MikeR
[Re: A12]
#816538
09/28/10 07:20 PM
09/28/10 07:20 PM
A12
N.E. OHIO, USA
Dave I guess my Tractor Supply Company lead isn't going to be of much help for you, duh for me sorry mate? But I'm sure you'll find one like the example in my previous post. MikeR
[Re: ademon]
#816543
09/29/10 10:22 AM
09/29/10 10:22 AM
A12
N.E. OHIO, USA
I'm going to gut this one for the day or year two look
Mike, where did you find that? It almost looks like an OEM Mopar battery from the same manufacture.
[Re: 05dakota]
#816546
09/30/10 06:22 PM
09/30/10 06:22 PM
A12
N.E. OHIO, USA
which are too wide for many factory hold downs
Battery Topper
ALL three of the Mopar toppers that are listed there are too wide for the factory hold downs. The three that are shown are the same group 24 battery topper but with different color caps. Because they have to cover and fit over a group 24 battery case (which has been the same basic dimensions for decades) the top is a little bigger than the battery. This would not be a problem if the battery was held in place by a clamp on the bottom or by individual rods that were not connected across the top. Because the top is a little wider than the battery and the top clamps are joined together by a straight or "Z" rod, therein lies the problem. BTW a group 27 size topper would be nice IMO.
MikeR
