Z bar linkage with a Lakewood Shield #815736
09/27/10 01:12 PM
09/27/10 01:12 PM
NE
moparpoolman Offline OP
NE
I have a 68 Plymouth GTX 4spd, Anyone have a problem with the Z bar linkage after installing a Lakewood? Mine seems to be not perfectly straight across and tight and binding(not a smooth movement) when I'm trying to let out the clutch slowly. Any soulutions or ideas? Thanks
Re: Z bar linkage with a Lakewood Shield [Re: moparpoolman] #815737
09/27/10 01:33 PM
09/27/10 01:33 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have seen that on an E body before , it's the bellhousing , you might try elongating the hole on the frame bracket with a rat tail file or you'll have to move the bracket on the bell. I did trim a little off the end of the Z bar at the bell end on the E body as the Zbar was hitting the side of the ballstud and causing it to bind a little .
Re: Z bar linkage with a Lakewood Shield [Re: JohnRR] #815738
09/27/10 09:46 PM
09/27/10 09:46 PM
NE
NE
Does anyone make offset Zbar ball ends?
Re: Z bar linkage with a Lakewood Shield [Re: moparpoolman] #815739
09/28/10 02:23 AM
09/28/10 02:23 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Wow, thats interesting. I had the exact same problem with my 68 GTX 4spd/Lakewood back in the mid 80's. I don't remember what I did, sorry, but I remember going through a few throw out bearings before i figured something out. Don't know,I might've tacked & then welded it where it worked, don't remember.
Re: Z bar linkage with a Lakewood Shield [Re: moparpoolman] #815740
09/28/10 10:15 AM
09/28/10 10:15 AM
JohnRR Offline
JohnRR  Offline
Yes ... YOU .
Never seen one and how would the maker of such a part know exactly how much offset to make for a production line built vehicle ?
Re: Z bar linkage with a Lakewood Shield [Re: moparpoolman] #815741
09/28/10 11:16 AM
09/28/10 11:16 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have a '69 RR with 11" clutch. The problem I had was the z-bar tube was too long. Had to remove one arm, move it over, reweld and shorten the tube.
How "not straight across" is it? Alignment doesn't have to be bang on. Disconnect all the linkage and move it by hand to find the bind spot. May just need a little trim.
Re: Z bar linkage with a Lakewood Shield [Re: Stanton] #815742
09/28/10 09:09 PM
09/28/10 09:09 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
I had to buy a McLeod hydraulic throw out bearing set up.
Now its perfect.
Come by and take a look.
I added hydroboost for the brakes too.
Re: Z bar linkage with a Lakewood Shield [Re: Rustydog] #815743
09/28/10 11:33 PM
09/28/10 11:33 PM
New England
jmac81d Offline
jmac81d  Offline
New England
I have had the same problem! Z bar checked out fine. Actuated the clutch fork without linkage and it still bound up. I found the problem to be the clutch fork pivot bracket not square to the centerline of the Lakewood bellhousing. When you press the clutch, the clutch fork tries to align correctly with mis-aligned pivot bracket resulting in the fork putting a side load on throw out bearing causing binding and wear on the input shaft bearing retaing tube and the throwout bearing. Your problem may not be the linkage. I struggled for weeks trying to figure this out, solved it last night. No more binding at all. Worth checking out! Good luck..
Re: Z bar linkage with a Lakewood Shield [Re: jmac81d] #815744
09/30/10 01:14 AM
09/30/10 01:14 AM
NE
NE
I think I have the same problem, How did you fix it? I sprayed some grease only on the back of the fork at the pivot point, seemed to help but not sure if problem is solved??? What did you do???
Re: Z bar linkage with a Lakewood Shield [Re: moparpoolman] #815745
09/30/10 01:44 AM
09/30/10 01:44 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...I'm going to guess he slotted the holes on the little angle bracket & that let the fork pivot more true. Just a guess.
Re: Z bar linkage with a Lakewood Shield [Re: thehemikid] #815746
09/30/10 10:20 PM
09/30/10 10:20 PM
New England
jmac81d Offline
jmac81d  Offline
New England
Yes, that is how I corrected the misalignment of the bracket. I slotted one of the holes with a carbide burr which allowed for adjustment. The bracket is hardened and a file hardly scratches it. All the lubricant in the world will not solve the problem. I have seen many bearing retainer guide tubes worn out along one side. I think this due the blade type pivot bracket not properly aligned. Very little clearance to accommodate any bracket misalignment. I made a little chipboard square that allowed me to set the bracket square to the centerline of the trans by centering off the IBR hole in the bellhousing.
