stock distributor specs #81534
06/29/08 10:56 AM
06/29/08 10:56 AM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
i was wondering what the stock mopar hei type distributor specs are? the kind you buy at autozone. i dont have one to check..
inital plate?
spring mechanical advance?
vacuum pod range?
Re: stock distributor specs [Re: mark7171] #81535
06/29/08 11:16 AM
06/29/08 11:16 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
They come with the "pink" springs. Advance starts at about 1000 rpm. Advance is adjusted to give 28 degrees all in at about 2200 rpm.
