Page 1 of 3 1 2 3
Help ID this 340 head setup, looks hardcore !!!!! #815021
09/26/10 05:07 PM
09/26/10 05:07 PM
Hazlet, NJ
440Satellite Offline OP
super gas
super gas
Hazlet, NJ
Hey guys, I just picked up and brought home a complete and running 340/904 tranny setup I bought on ebay. Anyway first I noticed the intake had some light porting under the carb, then I took off the valve covers to find some pretty hard core setup that I havent seen before. Now they are J heads and the motor is block #
2780930 340 5 and date coded 7 2 70. But there seems to be dual springs with dampers, non-steel retainers( any ideas) and big aluminum blocks for bolting down the adjustabe rockers. Also if you look down the head into the block there is a big aluminum plate with holes for the pushrods that I've never seen before.
So can anyone tell me anthing about this setup? It was soposedly a good running motor but I'm gonna tear it down to inspect and see what else lies beneith, but I figure maybe someone can help me out on this one. Heres a few pictures.
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815022
09/26/10 05:08 PM
09/26/10 05:08 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
another
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815023
09/26/10 05:09 PM
09/26/10 05:09 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
one more
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815024
09/26/10 05:10 PM
09/26/10 05:10 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
and another
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815025
09/26/10 10:09 PM
09/26/10 10:09 PM
Locomotion Offline
Locomotion  Offline
If the retainers are aluminum, recycle them ASAP before you have to recycle the whole engine. If they are titanium retainers, you're fine.
The blocks were a valvetrain trick to help geometry, usually with long stem valves and/or get clearance for larger diameter valve springs. Milled rocker shaft pads were standard on race W-2 heads. Econo W-2 had OEM-style cast stands.
Double-check the rocker contact patch on the valve to make sure it's not to far inward towards the shafts.
The plate inside may be a Milodon or similar valley tray that has a pair of spring steel straps that snap under the heads. It keeps the lifter in its bore in case there is a valvetrain failure. Otherwise, a lifter popping out could cause rapid oil pressure loss.
The intake looks like an original Edelbrock Torker or Tarantula intake. My personal opinion is that either one is junk compared to what is available today.
I also just noticed that the oil squirt holes on top of the rockers have been closed off with a set screw!
Do the hold-down bolts go through the middle of the rocker shaft or is the shaft offset towards the intake?
Intersting set-up. I'm curious what's inside too!
This should probably be in the Unlawful's Race Only section.
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815026
09/26/10 10:24 PM
09/26/10 10:24 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Are you sure those are J-heads? What is the casting number? Also, could you take a photo of the numbers on the front of the block under the drivers head and post it? (see example)
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: ScottSmith_Harms] #815027
09/26/10 10:34 PM
09/26/10 10:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
VIN from the pad on the passenger side of the block too please?
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: Locomotion] #815028
09/26/10 11:34 PM
09/26/10 11:34 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Ok, first is there a way to tell if the retainers are aluminum or titanium, looks like this motors seen a good amount of use and there still looking good. And your right on the blocks, the rocker shaft mount was milled down, the bolt goes throught the rocker shaft and block and into the head where it normally bolts up, but with larger bolts. Ans your also right on the valley pan , I took the intake off and it is held on with 2 spring straps, so your probably right there too.
Well I got the intake off and pulled one head, they are indeed J heads, with what looks like stainless 2.02 intake and exhaust valves. Looks like they did some heavy port matching as the intake port on all of them hit the valve cover bolt area in between intake ports.
Also after pulling the heads I found TRW .030 over L-2322 forged dome pistons. The cylinder walls look great, there isnt even a ridge on top once I wipe away the carbon, and I can still see cross hatch. Strange thing is, that there is no notable bore scorring or were, but the pistons are really loose in the bore, but I was able to see one top ring gap and by eye it looks good. Now heres the other thing, the pistons look like the valve reliefs were cut deeper, and thy must have cut too deep on one, cause a couple chunks are missing. But with the piston with the missing peice, the walls look great and there no chunk in the bore, and it looks like it has been runn for a long time like this?
So heres a few more pictures, what do you think, can that one piston be run like that, well it was running so I quess I answered my own question. But why would pistons be run so loose?
Butch
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815029
09/26/10 11:37 PM
09/26/10 11:37 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Ohh yeah the drivers side front block # is
G340P33750547 then theres a 43 with a 3 under thats stamped sideways
And the heads are AAWJ
3418915(G or C cant tell)
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815030
09/26/10 11:38 PM
09/26/10 11:38 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Rocker shaft boss...
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815031
09/26/10 11:39 PM
09/26/10 11:39 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
More
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815032
09/26/10 11:39 PM
09/26/10 11:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
71 model year 340 built around Oct 24, 1970
Those pistons look like the old TRW 12.5:1 slugs.
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815033
09/26/10 11:40 PM
09/26/10 11:40 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Valley pan,,,
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815034
09/26/10 11:44 PM
09/26/10 11:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Looks like you left a letter out after the G? At any rate what you posted breaks down as a:
G-Series (1971 model year) 340
P = Premium Fuel
October 24th 1970 Assembly date
547th engine assembled
Cool engine, but you better have lots of race fuel around with those pistons, that is one old school build! IMO I'd tear it down and start over with all fresh parts, pistons, rockers, etc. Maybe even the heads if those have been overly ported.
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815035
09/26/10 11:46 PM
09/26/10 11:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Most likely 3418915
They can be hard to read at times, but 915 goes with J & a few other letters.
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: Alaskan_TA] #815036
09/27/10 01:43 AM
09/27/10 01:43 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Those valve releifs have been machined deeper than my set of the same pistons, that is why they broke through on the ring lands. Those pistons are not too high of compression with stock heads, they don't come in anywhere near what they are suposed to unless the heads or deck have been milled a lot.
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: Alaskan_TA] #815037
09/27/10 01:44 AM
09/27/10 01:44 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Looks old school, and OLD, go over everything with a fine tooth comb.
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: HotRodDave] #815038
09/27/10 01:47 AM
09/27/10 01:47 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
...... that is why they broke through on the ring lands ......
Looks like they "burned through" to the ring & cylinder wall, look at the burn mark at the top of the cylinder.
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: HotRodDave] #815039
09/27/10 07:01 AM
09/27/10 07:01 AM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Ok heres another picture of the damaged piston.
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815040
09/27/10 07:05 AM
09/27/10 07:05 AM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
And heres a good shot where you can see how loose it is, look at how much ring you can see on the sides, now keep in mind that this motor is filthy on the outside and going by the gaskets, hasnt been apart in a long time, looks like since it was built. What would be the reason for such loose pistons.
Page 1 of 3 1 2 3
