New motor running rough-BBC
#814240
09/25/10 08:39 PM
09/25/10 08:39 PM
Posts: 4,503 NJ
440challenger
NJ
Ok dont shoot me, im a die hard mopar guy, and i almost converted my die hard chevy old man to 100% mopar. BUT We finnaly got his BB CHEVY in his chevelle and running which we've been building together for years. Its a 13-1 comp 720 roller cam dart head 496 stroker. Compression on all cylinders is 175-180 Plugs are NOT hitting the pistons closing the gaps Ignition is a msd6al we just got back from msd (reconditioned) Firing order is correct and timing is at 36 total. 1050 dom .. it had 88 squared jetting with 5 power valve front and rear.Fuel pressure 7psi. I blocked the rear and went to 84 fronts and it made no difference. Its running like it has a bad miss-revs up very rough...Im not sure where to go from here. I told him lets try putting an hei diz in to eliminate the msd and see if it makes a diff. Running no alt(havent hooked one up yet,just batt volatge with a charger on it). Any pointers on where to start? Thanks guys!
Re: New motor running rough-BBC
[Re: 440challenger]
#814241
09/25/10 08:43 PM
09/25/10 08:43 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
1) Have you mechanically confirmed TDC?
2) Have you looked at the rocker gear and valve adjustment since starting it?
3) Double checked plug wires and swapped and/or changed spark plugs?
RIP Monte Smith
[Re: 440challenger]
#814245
09/25/10 09:30 PM
09/25/10 09:30 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
Make sure the power valve is good and the gasket is correctly seated. Both can cause it to run very poor and rich.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
[Re: 440challenger]
#814246
09/25/10 09:31 PM
09/25/10 09:31 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
Are you sure the cam isn't a 4/7 swap.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
