Flaming river manual gearbox, pitman arm question
#814090
09/25/10 05:59 PM
09/25/10 05:59 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Just a quick question. If I use the flaming river 16:1 manual steering box to replace the power steering in my 71 valiant, will I need a new pitman arm as well?
Thanks, -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: Flaming river manual gearbox, pitman arm question
[Re: blown340]
#814091
09/26/10 01:38 AM
09/26/10 01:38 AM
blown340
Walnut Creek, CA
[Re: blown340]
#814092
09/26/10 01:50 AM
09/26/10 01:50 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
Thanks, -Jon
What diameter is the output splines on the Flaming River box? If it's the same small diameter style, it the same pitman.
I believe all stock manual 62-76 A-body boxes have the same small output diameter. So I think you will be fine, but I would not assume anything with an aftermarket part/box.
http://www.bigblockdart.com/techpages/moognumbers.shtml Manual Power 67-72 A body (exc 383) K7074 K7074 73-76 A body K7075 K7076
