use a vac gauge along with the timing light
set timeing for highest vac reading
adjust idle air screws on carb to highest vac reading
back and forth till you get the bestest highest reading with vac can on dist unhooked
adjust curb idle on carb and repeat steps to fine tune it
old racer trick is to set cub idle,use vac gauge and turn dist to get highest vac reading...back off one full number
i.e....if your highest is 14..back off to 13 and test drive it,,adjust again if needed
rpms should only drop a little when going from N to D at an idle and not jeck the car as it goes in gear
results will vary
find what your engine likes and use those numbers,,they may differ slightly than any books
