Can a BB damper be used on a Hemi? #813076
09/24/10 12:16 AM
09/24/10 12:16 AM
Austin, TX
HemiDave Offline OP
HemiDave  Offline OP
Austin, TX
Can an old style BB Fluid Damper work on a Hemi? There are timing mark issues, right?
Thanks!
Re: Can a BB damper be used on a Hemi? [Re: HemiDave] #813077
09/24/10 12:33 AM
09/24/10 12:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes you can use it , crate motors came with the thin B/RB balancer. Timing marks in the same place, TDC is TDC ...
Re: Can a BB damper be used on a Hemi? [Re: HemiDave] #813078
09/24/10 05:19 PM
09/24/10 05:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you use the BB damper you'll have to use the BB pulleys, the Hemi pulleys are different.
Re: Can a BB damper be used on a Hemi? [Re: John_Kunkel] #813079
09/24/10 05:22 PM
09/24/10 05:22 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I used a BB fluid damper on my hemi with BB pulleys. Works great.
