71-72 Door Hinge Parts #811067
09/21/10 07:03 PM
09/21/10 07:03 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
Where can you get the roller the detent arm and a spring for the lower door hinge on a 72 B-body
Thanks Moparts
Re: 71-72 Door Hinge Parts [Re: 72 RR DUDE] #811068
09/21/10 08:28 PM
09/21/10 08:28 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
there are 2 styles of lower hinges on the 71/72 Bs
#1 is the coil spring style, when the spring and arm go bad its junk. throw it away
#2 is the wire spring style. this hinge is used on all B bodys from 71 and up. the 73/93 trucks use the same hinge also..
I am truckless..
