big block head info and casting number id #811049
09/21/10 06:57 PM
09/21/10 06:57 PM
plymouth, NH
E
ejtmopar Offline OP
ejtmopar  Offline OP
E
plymouth, NH
Anyone got any info on this number?
2866643
Heads any good for a mild build?
Re: big block head info and casting number id [Re: ejtmopar] #811050
09/21/10 09:48 PM
09/21/10 09:48 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Are you sure those are the casting numbers? Cant find that Number anywhere.
Re: big block head info and casting number id [Re: R/T1968R/T] #811051
09/21/10 10:00 PM
09/21/10 10:00 PM
Amherst,NY
challengermike Offline
Amherst,NY
i cant either.maybe mopar performace aftermarket heads?
Re: big block head info and casting number id [Re: ejtmopar] #811052
09/22/10 09:02 AM
09/22/10 09:02 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
This guy says they're truck heads.
http://nh.craigslist.org/pts/1939247409.html
Re: big block head info and casting number id [Re: Commando1] #811053
09/22/10 09:40 AM
09/22/10 09:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There you go ... you beloved MOTORHOME heads , and they are only a C note ... they are local to me and my parents are driving back down to orlando tomorrow morning , do you want them ???
Re: big block head info and casting number id [Re: JohnRR] #811054
09/22/10 01:19 PM
09/22/10 01:19 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Be aware that those heads require a specific exhaust manifold and have ports at the front of the head for the water housing (the heads get water first).
don't know if you can block off those ports and cool them in 'normal' style, but regardless, you will be stuck by the manifold. They reproduce them for motorhome use.
Re: big block head info and casting number id [Re: Fury Fan] #811055
09/22/10 03:52 PM
09/22/10 03:52 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...I've seen these heads on a D 700 (swing out fender) truck. I think it was a 361ci. The exhaust port extense's out past the "normal" heads that we are used to.
Re: big block head info and casting number id [Re: thehemikid] #811056
09/22/10 04:36 PM
09/22/10 04:36 PM
plymouth, NH
E
ejtmopar Offline OP
ejtmopar  Offline OP
E
plymouth, NH
I thought thats what they might be... Wasnt sure cause i coulnt find the number anywhere. Ill just build the 452's i have.. thanks for the info..
