Motor mount rubber part #81070
06/28/08 05:55 PM
06/28/08 05:55 PM
Pizza Bucket
snuggles Offline OP
snuggles  Offline OP
Pizza Bucket
Is the rubber insert replacable on the motor mount likke a trans mount is? If so where to get them?
Re: Motor mount rubber part [Re: snuggles] #81071
06/28/08 06:00 PM
06/28/08 06:00 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Kinda like These...
Re: Motor mount rubber part [Re: OzHemi] #81072
06/28/08 06:10 PM
06/28/08 06:10 PM
Pizza Bucket
snuggles Offline OP
snuggles  Offline OP
Pizza Bucket
Those would be it. I did a search and didn't see anything. Didn'y even think about the summit site. Looks like I can have them in red also. Thanks I'll just go back out to the garage for now.
Re: Motor mount rubber part [Re: snuggles] #81073
06/28/08 07:22 PM
06/28/08 07:22 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
The ProThans and Energy Suspension bushings are polyurethane. If you do decided to use poly bushings, you'll need to re-use the metal sleeves from the stock rubber inserts, just like with a trans mount.
Stock rubber engine mount inserts are available from the parts stores for about $15.00 each.
