How in the world would you fix this stripped thread???
#809667
09/20/10 08:02 PM
09/20/10 08:02 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Stripped a bolt hole on my torque converter during install. I DO NOT want to have to take this thing out all the way again. It will tighten to a certain extent and then skip back out at a certain point.
Clearly a heli coil would be best, but is the mounting pad on a toque converter deep enough for one? I'm guessing I would have to cut an insert down in length. Also how far can I drill into it without going into the converter itself. And I'm also guessing I would need to find a bottoming tap to get the threads for the insert deep enough to make a difference. Does any store typically carry bottoming taps?
Also looked at the specs for the permatex thread repair compound. Looks like the recommended torque for a repaired thread is very low.
Any suggestions would be greatly appreciated.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: How in the world would you fix this stripped thread???
[Re: Michael Ecks]
#809668
09/20/10 08:12 PM
09/20/10 08:12 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Take it out, cut off the little block, weld the hole up, re-drill and tap it, and then weld it back on in the correct location.
Or, look at this as your big chance to get the new torque converter you've always wanted.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: DAYCLONA]
#809670
09/20/10 08:27 PM
09/20/10 08:27 PM
Michael Ecks
Columbus, GA
I'm liking Dayclona's suggestion wayyyy better.
[Re: Michael Ecks]
#809671
09/20/10 08:31 PM
09/20/10 08:31 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
I think that it is, or you can get it to work. If not, it will need to come out for repair IMO.
[Re: stumpy]
#809673
09/20/10 10:09 PM
09/20/10 10:09 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
screw a short stud into the hole and tack weld it..
I am truckless..
[Re: DAYCLONA]
#809674
09/20/10 10:53 PM
09/20/10 10:53 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Consider using a metric sized bolt that's close to the hole size you have, just slightly oversized...just check out a few tap charts to see what size you can go to,...a metric starter and bottoming tap would do the job, no drilling, just tap, and go
