Re: Will a 38 Dodge radiator cool a 440?
[Re: earlymopar]
#808642
10/04/10 03:20 PM
10/04/10 03:20 PM
Posts: 1,318 central Kentucky
moprod
central Kentucky
Got a Aluminum radiator in my '35, new water pump, new 180 thermo and mine still runs warmer than I like. Yesterday, 55 degree weather on the interstate running 195, stop in traffic goes to 210. Have no room for a factory type fan, only using electric puller set to kick on at 185. I have an electric gauge wondering if a mechanical would read different, car shows no signs of overheating?
[img] [/img]
[Re: moprod]
#808643
10/05/10 01:20 AM
10/05/10 01:20 AM
Posts: 10,558 Freeport IL USA
poorboy
Freeport IL USA
I have to wonder how congested it is under your hood. For the cooling system to function, air that passes through the rad has to be able to exit from under the hood. Many guys close up most of the air exit routes with street rods. When the flathead 6 was there, air exited around the sides of the engine, through the louvers on the inner fender panels, and under the floor around the bell housing. When you fill those areas with V8 engine, headers, brake boosters, and remove the louvered inner panels, you leave little room for the heated are to exit.Look for ways to improve air flow through the engine compartment.
Also, over heating on the highway can be caused by a lean engine, too advanced timing, or moving the coolant through the system too quickly. Could be a defective gauge but really, 210 is not overheating, water boils at 212 and if its under pressure like in a closed cooling system, that boiling point can be as high as 250. It may be higher then you (and I) would like, but not hot enough to damage the engine. How does it do when it gets hot outside, or driven around town? Gene
[Re: poorboy]
#808644
10/05/10 10:00 AM
10/05/10 10:00 AM
moprod
central Kentucky
Gene, in the summer when temps were in the 90's it still ran the same temps. The louvered inner fenders are still in the car also.
[img] [/img]
[Re: moprod]
#808645
10/06/10 12:18 AM
10/06/10 12:18 AM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I also have an aluminum radiator in the 36, the small block does fill up the engine bay. I had a problem with the fan coming on at 220, engine temp. Moved the fan switch from the radiator to the intake. Now it comes on at 200 and off around 190, no more dieseling and seems to be cooler all around.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: earlymopar]
#808646
10/06/10 05:51 PM
10/06/10 05:51 PM
Posts: 40 Santa Cruz, Ca
4woody
Santa Cruz, Ca
I did not have a stock radiator to rebuild in doing my 37' Dodge. I also felt and feel that most of the aftermarket radiators that are made for 30's era cars are way over-priced even though they are good products.
I bought a $180 aluminum cross-flow radiator (summit or others), turned it 90 degrees to fit my narrow grill shell and radiator support, plugged the existing inlets and outlets and added an inlet and outlet in the upper and lower radiator hoses. Works great.
- EM
Got a photo? You plugged the existing inlet/outlet and then put new ones into the tank??
Just want to understand what all you did. Thanks
[Re: 49wayfarer]
#808653
11/26/10 03:06 AM
11/26/10 03:06 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
i have found that a mechincal fan works better,even in the tightest places,,or an electric puller that has a built in shroud,,or make a shroud.,,,,do a search on the H A M B ive seen some clever home made fan shrouds
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
