69' B-body sideview mirror "loose" #808626
09/19/10 10:13 PM
09/19/10 10:13 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Does anyone have any tricks/tips/ideas on how to tighten up the mirror head? There is a ball that fits into the back of the mirror housing and it is loose fitting at this point and won't stay in adjustment.
Re: 69' B-body sideview mirror "loose" [Re: pacifica] #808627
09/20/10 01:45 PM
09/20/10 01:45 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
We've taken a center punch & put "Dimples" all around the ball. Just that little bit tightens it up. You have to move the mirror head around to get all the areas needed to get it tight for the position it usually sits in.
Butch
Re: 69' B-body sideview mirror "loose" [Re: pacifica] #808628
09/20/10 01:54 PM
09/20/10 01:54 PM
Wattsburg, Pa
Dr V Offline
Dr V  Offline
Wattsburg, Pa
Never had a 69 apart. But the 70-74's have a plate behind the glass that needs to have more tension on it. Usually the pot metal rivets from the factory either wear or break. Problem is, if u cant get the glass to come out after heating it. You may need new glass too.
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: 69' B-body sideview mirror "loose" [Re: CHRYCOFAN] #808629
09/20/10 02:37 PM
09/20/10 02:37 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Awesome reply CHRYCO / BUTCH
It worked great!!!!!!!
Thanks a million!!!
Steve
Re: 69' B-body sideview mirror "loose" [Re: pacifica] #808630
09/20/10 02:42 PM
09/20/10 02:42 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I've taken them apart and tightened up the plate that applies friction to the ball. I've broke one mirror glass and another came right out. The newer reproduction mirror I have has screws that just needed tightened.
Re: 69' B-body sideview mirror "loose" [Re: Paul_B] #808631
09/21/10 11:38 AM
09/21/10 11:38 AM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
You're Welcome! the nice thing about that fix is you don't have to worry about breaking the mirror.
Had to do it to an NOS Pass-side manual mirror of all things.
Butch
