Hi there,
I've just installed the Moog 7103's aswell on my ute and had a hard time getting the arm's back in.
these Moog bushings seem a bit wider than the stock type that we get here in OZ, I think it's got alot to do with the washers they supply are thicker than the OME type, anyway what i did to get my arm's in was to put a small bend on the outside washers, maybe 45 deg or less on the bottom of the large washers, now you don't want to bend to much, I just put the very tip of the washer in the vice and give it a sharp bump close to the gaws.
This was all it needed, so i could bump it in with a rubber mallat. hope this helps.
