Re: early A UCA bushing install prob [Re: autoxcuda] #807587
09/20/10 05:47 PM
09/20/10 05:47 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
On my sons 68 Dart I used a Poly kit for my 65 Cuda. But in my sons car we had welded up all the gaps and I installed gussets to the tabs of where the UCA bolts in. This made the whole area so much sturder. But it was a bear getting the control arms in. Was tight but a "little rap" with a 2 lb hammer and they popped into place. Alignment was spot on when done.
We'r talking about old stuff here and things have moved a bit from its first birthday, and so has our cars frontends.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: early A UCA bushing install prob [Re: Dave_J] #807588
09/20/10 06:18 PM
09/20/10 06:18 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
On my sons 68 Dart I used a Poly kit for my 65 Cuda. But in my sons car we had welded up all the gaps and I installed gussets to the tabs of where the UCA bolts in...
Good idea to gusset that area. Real common to find cracks in A-bodies around there.
Re: early A UCA bushing install prob [Re: autoxcuda] #807589
09/20/10 07:50 PM
09/20/10 07:50 PM
RapidRobert Offline OP
Sorry, please don't fire me.
Steve we are good & now I understand why the discrepency in the dimentions and I must have bent them when cranking the upper ball joints real tight. I didn't think an UCA would bend that easy. thank you for taking the time to measure and take pics of this. the bushings in there were actually fine but I had the new ones in the kit so I wanted to change them to feel I was making some progress
Re: early A UCA bushing install prob [Re: RapidRobert] #807590
09/21/10 09:11 AM
09/21/10 09:11 AM
Australia
dodgy Offline
dodgy  Offline
Australia
Hi there,
I've just installed the Moog 7103's aswell on my ute and had a hard time getting the arm's back in.
these Moog bushings seem a bit wider than the stock type that we get here in OZ, I think it's got alot to do with the washers they supply are thicker than the OME type, anyway what i did to get my arm's in was to put a small bend on the outside washers, maybe 45 deg or less on the bottom of the large washers, now you don't want to bend to much, I just put the very tip of the washer in the vice and give it a sharp bump close to the gaws.
This was all it needed, so i could bump it in with a rubber mallat. hope this helps.
