68 440 cam specs?? #80479
06/27/08 12:01 PM
06/27/08 12:01 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
I am looking for the stock cam specs for a 1968 dodge charger 440.
Mopar Perf. lists a resto cam #p4452783: 228/241 @0.050", 115 centerline (is this the lobe sep angle??), .450/.458" lift.
Comp Cams lists a "factory id" cam #21-305-4: 222/226 @0.050", 110 lobe sep angle, .464/.464 lift.
Does anyone know what the real stock cam specs are for this engine or where to possibly find it? One would think this info would be available somewhere. Thanks a bunch!!
PJ
Re: 68 440 cam specs?? [Re: PJ68RT] #80480
06/27/08 01:26 PM
06/27/08 01:26 PM
Wis., USA
Bob_Fromm Offline
Bob_Fromm  Offline
Wis., USA
The Mopar "resto" cam is bascially a re-grind of the original cam. The Mopar cam specs are the same as the original cam. The Comp cam is "their-own" improved version.
Re: 68 440 cam specs?? [Re: Bob_Fromm] #80481
06/27/08 01:56 PM
06/27/08 01:56 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
Thanks for the reply.
The mopar cam says 115 centerline. Is this the Lobe sep. angle...or something else?? Thanks again
Re: 68 440 cam specs?? [Re: PJ68RT] #80482
06/27/08 03:02 PM
06/27/08 03:02 PM
BRawls Offline
super gas
BRawls  Offline
super gas
Centerline is the intake lobe centerline in degrees from TDC. This is what you would use to degree the cam. The separation angle is the difference between the intake lobe centerline and the exhaust lobe centerline.
