what size wheels on front of 73+ A-bodies? #799417
09/12/10 06:00 PM
09/12/10 06:00 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
I need to order a pair of Cragars for the front of my 73 Duster, I have disc brakes.
I'd just order something but i had some old slotted mags kicking around, they are 14x7, 3.5" backspacing, and with a 235/60 tire, on a sharp turn the tire will hit the front edge of the wheel arc at the bottom.
I was thinking a 15 or 14x6 Cragar, with 4.5" BS would be good on a 215x70
what do you guys have?
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: what size wheels on front of 73+ A-bodies? [Re: MonGoo$e] #799418
09/12/10 11:21 PM
09/12/10 11:21 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
wow.
Re: what size wheels on front of 73+ A-bodies? [Re: MonGoo$e] #799419
09/13/10 03:59 AM
09/13/10 03:59 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Probably 3 3/4 to 4 inch will be fine , with either a 14 or 15 inch. Considering the 14 inch ralley and steel wheels had 3 5/8 backspace.
Frank
Re: what size wheels on front of 73+ A-bodies? [Re: duster2] #799420
09/13/10 04:36 AM
09/13/10 04:36 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Frank
I disagree with the 15". 3 3/4 or 4 inch will not work with a tall 215/70/15 tire and 15x6 rim. You'd need a shorter tire. 14x6 with 215/70/14 and 4.0 backspacing might work though.
Typically 225/60/15 with 15x7 with 4.25 is about maxed out. I think 15x6 with 215/70/15 would work with 4.5 backspacing. 14x6 with 215/70/14 and 4.5 backspacing will definitly work.
Re: what size wheels on front of 73+ A-bodies? [Re: autoxcuda] #799421
09/13/10 12:22 PM
09/13/10 12:22 PM
florida
74fldart Offline
74fldart  Offline
florida
i have on my 74 dart a pair of 15 x 7 wheels with 4 " backspacing and 215/60 tires and they clear everything ok but the tires stick out past the fenders about 1 " , which is a look i dont like.
Re: what size wheels on front of 73+ A-bodies? [Re: 74fldart] #799422
09/13/10 01:32 PM
09/13/10 01:32 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
thats odd, the 14x7s i had on temp. was 3.5 BS and didn't stick out with a 235/60
I cannot remember which corner hits that front edge, is it the inside of the tire or outside? I keep thinking outside but more backspacing almost seems to make it worse, almost doesn't I can't get my head straight
Re: what size wheels on front of 73+ A-bodies? [Re: 74fldart] #799423
09/13/10 02:48 PM
09/13/10 02:48 PM
western Ky
CraigS Offline
CraigS  Offline
western Ky
biggest size tire i can fit without rubbing is a 205/60/15 on 15 x 7 rim with 3.5 " backspace ,thats on a 69 dart with 73 up discs.
that said ,I am runnin 215/60/15 on it now ,rubs a little at front of wheelwell
Re: what size wheels on front of 73+ A-bodies? [Re: CraigS] #799424
09/13/10 04:49 PM
09/13/10 04:49 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
I have 225 60 15 on 6-1/2 with 4" BS and thay do not rub
Re: what size wheels on front of 73+ A-bodies? [Re: bp27] #799425
09/13/10 06:43 PM
09/13/10 06:43 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
thanks for the replies guys, really helps as I'm suspect of simply making measurements.
It's easier on the rear wheels, they just go up and down.
