Cheapest 5 speed conversion for my Duster?
#79877
06/26/08 01:56 AM
06/26/08 01:56 AM
I want a 5 speed!
I have a 72 Duster, 318 with a 904 right now. What is the cheapest option?
I thought it would be a T5 but after hours searching it doesn't seem like anyone is running them.
What are the options without spending 3k? Thanks Jeff
Re: Cheapest 5 speed conversion for my Duster?
#79878
06/26/08 04:49 AM
06/26/08 04:49 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
cheapest would be a 5 spd out of a mustang GT in the junk yard. grab everything off it that you can. I think they run the T-5 right? all you need is a mopar bell, flywheel and clutch set up.
what's a junkyard T-5 going for anyway? $500? $800? it's gotta be cheap, since a brand new TKO gearbox can be ordered from Jegs or Summitt for around 1800.
if the 318 is not built up very much the T-5 should handle it ok, but the reason most people don't like the T5 is if you look at the torque rating, it's only good to like 300 ft lbs, and most of our Mopar engines are built up enough taht they far exceed that and require the beef of the TKO500 or 600.
**Photobucket sucks**
[Re: 70Cuda383]
#79879
06/26/08 04:50 AM
06/26/08 04:50 AM
70Cuda383
Marysville, O-H-I-O
oh, I forgot about Dakota/Ram transmissions! they are already set up for a mopar small block, the NV3500 might be good. the AX15 from dakota V6s is a small transmission but would be questionable behind the 318.
[Re: 70Cuda383]
#79880
06/26/08 08:17 AM
06/26/08 08:17 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
The down sides to the Ram/Van 5-speeds like the 3500 and AX-5 & AX-15 are that they have nice truck gear ratios (3.8-4.x:1 first gears), and they're physically large boxes in spite of relatively low torque capacities. Major floor and t-bar X-member surgery WILL be required with those transmissions. However, the architecture of those transmissions is shared across a wide range of other Aisin/Warner boxes, including the ones used in the new Chebby Colorado trucks, and the Solstice/Sky roadster twins, among many others. You can see how large the trans is, and track the progress that Buschi340 is making on his install of a similar Toyota Supra Turbo transmission in this thread. I'm going to install the same trans, only because I got a better deal on it than any of the T-5's in my area... that said, T-5's can be had for cheap, I've been quoted $3-400 for nice used units at local salvage yards, and some pick-n-pull yards sell them for $75 or so. I think even current V-6 mustangs still use the T-5, so it's a solid, stout, light transmission with a huge amount of aftermarket support. I think there will still be some cutting involved on the t-bar X-member, though. Seems that there just isn't much you can do about hacking up an A-body. Clair
[Re: 69Cuda340S]
#79882
06/26/08 12:08 PM
06/26/08 12:08 PM
Posts: 182 Columbia, Missouri
dtedler
Columbia, Missouri
I would recommend evaluating the true horsepower and torque of your car and start from there. Be honest and choose wisely. You may perform the best swap imaginable, but the first time you hammer the car and blow the transmission, is it worth it doing it over and over again. The T5 is rated at approx. 270 lbs.ft. of torque, which a warmed up 318 can approach easily these days. My advise would be a TKO-500. One thing to remember is to identify the weak link, if it's not the transmission, does it become the u-joints, the drive shaft, the rear end (center section, axles), etc.
[Re: Clair_Davis]
#79886
06/26/08 03:33 PM
06/26/08 03:33 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
It might... I think OzHemi had to notch a wee bit out of his t-bar x-member to fit the T-5 behind his Hemi6. There may also be some potential to swap tailhousings with something from an S-10 truck or something that pulls the shifter tower forward. Maybe too far forward, but it's something to check. I know the guys over on slant6.org have done a lot of work swapping T-5's in to early A's, so it might be worth a look over there to see what they did.
Clair
Yep, I had to trim the upper part of the torsion bar crossmember abit, but other then that was not too big a deal, and made the car a ton better to drive versus the old 4 speed (original borq warner Aussie box) I used a WC T-5 from a Mustang GT...
The cross member I made, along with a stock one for comparison..
[Re: OzHemi]
#79889
06/26/08 06:28 PM
06/26/08 06:28 PM
OZ, how much HP are you putting through your T5? I know my 318 does put out that much power. Sure seems like there is alot of tweeked Mustangs that ran them with out any issues.
I heard from a few people that the 4cyl Mustangs have the same trans as the 5.0. Does anyone know if that is true.
Do you have a parts list I should grab from the donor car?, and what other parts I should start gathering.
My car has a 904 in it right now. I just bought some pedals. Do I need the Z bar?
Thanks again Jeff
#79890
06/26/08 07:29 PM
06/26/08 07:29 PM
OzHemi
Garden Grove, CA
Somewhere around 280 - 310 horsepower I would estimate.. I am not drag racing it, but have driven the car somewhat hard and had no issues. Car weight is less then some US cars that might help too, at abit under 3k pounds. The 4 cyl 'Stangs use a different length input shaft from memory, different ratios then a 5.0 and not sure if they are even WC boxes? The SVO cars "may" be an exception but I don't really know for sure.
[Re: OzHemi]
#79891
06/26/08 07:42 PM
06/26/08 07:42 PM
OK, a 5.0 it is.
Jeff
#79892
06/26/08 07:47 PM
06/26/08 07:47 PM
OzHemi
Garden Grove, CA
Well, for my swap the only thing I got from the Mustang was the trans itself. I used a bellhousing from Oz to adapt it, a new clutch, and a standard Hemi-6 flywheel basically. You'll need the Z bar like you mentioned too (unless you plan to go hydraulic) I used the stock mustang shifter box, but was always going to upgrade to a Pro 5.0 one. You'll have to make the trans crossmember too. I made mine up like you can see, and used a Chev universal trans mount with it
[Re: OzHemi]
#79893
06/26/08 10:35 PM
06/26/08 10:35 PM
I think I beter ask a few more Q's. I have found that when I don't it ends up costing me more cash and headaches.
Are all small block bell housings the same(318, 340, 360)?
For the clutch and pressure plate do I just use stock mopar 4 speed stuff or ???
I would like to go mechanical for the clutch. I think the T5's are hydraulic. How do you hook it up mechanical?
Sorry about all the Q's, I just want to learn as much as I can before I start the project.
Jeff
#79894
06/26/08 10:43 PM
06/26/08 10:43 PM
OzHemi
Garden Grove, CA
The small blocks are all the same bellhousing bolt pattern on the block, yes.. T5's where cable opperating the clutch fork (at least the 5.0 stuff was) you can get a hydraulic conversion if you wanted... On the clutch, I use a Mopar pressure plate and a disc the same outside diameter as the factory one, but with the Ford splines for the input shaft
[Re: OzHemi]
#79895
06/26/08 10:51 PM
06/26/08 10:51 PM
Do you have pics where the cable mounts to your Z bar?
Where or how do you get Mopar clutch with Ford T5 splines.
Thanks Again, Jeff
