Fixing cam lobes? #798127
09/10/10 07:05 PM
09/10/10 07:05 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I have a nice BB cam I really like. It's in excellent shape....except a single cam lobe is worn down. Can a shop build this lobe up with weld and then grind it back into shape? And if so does anyone in northern California know a good shop for this? Thanks!
Re: Fixing cam lobes? [Re: polkat] #798128
09/10/10 07:08 PM
09/10/10 07:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could buy a new cam for what it would cost to fix the old one.
Re: Fixing cam lobes? [Re: stumpy] #798129
09/10/10 07:12 PM
09/10/10 07:12 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Thanks stumpy. I kinda thought someone would say that. I'll start looking.
I kind of thought it was a little weird. 15 prestine lobes and one wiped! Any ideas as to what to look for as the cause? Oiling? Weird lifter? Sticky valve stem? Any ideas?
Re: Fixing cam lobes? [Re: polkat] #798130
09/10/10 07:23 PM
09/10/10 07:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How long has the cam been running in the engine? Hydraulic or solid?
Re: Fixing cam lobes? [Re: stumpy] #798131
09/10/10 08:19 PM
09/10/10 08:19 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
In the mid 70s I was in the CG at YBI. A friend got me a reground one from CAL CAMS in the bay area. there is DELTA CAMS up here in Tacoma Wa. But as Stumpy said the cost is virtually the same...
I am truckless..
Re: Fixing cam lobes? [Re: 340SHORTY] #798132
09/10/10 09:20 PM
09/10/10 09:20 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
It's just the factory 440 HP hydralic cam (not sure of the specs). Nothing special, but I've had one before and it did what I wanted. So I guess it has been running for nearly 40 years.
