Page 3 of 3 1 2 3
Re: Four (4) Headlights on relay's ?........ [Re: Ludington1] #79783
08/07/08 02:46 AM
08/07/08 02:46 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
you can use 14 without problem
Re: Four (4) Headlights on relay's ?........ [Re: NachoRT74] #79784
08/07/08 09:37 AM
08/07/08 09:37 AM
Here is my two relay setup for 2bulbs
http://www.goodysgotacuda.com/Headlights.html
the same for 4 head ligts just that high beams position will drive 4 beams. Is easy for a single relay.
HOWEVER I still would take the power from alt stud or any point on alt side of power to get teh right reading on ammeter.
YES & using Nacho's advice of adding 2 wires to bypass the black/red main connection points at the bulkhead connector.
Re: Four (4) Headlights on relay's ?........ [Re: Ludington1] #79785
08/07/08 09:52 AM
08/07/08 09:52 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
One more for this thread... what size of fuse are you guys putting between the alternator stud and the relays?
Thanks,
Darren
I'd have to look and get back to you on the size but mine has a fusable link and a fuse
Re: Four (4) Headlights on relay's ?........ [Re: Ludington1] #79786
08/07/08 10:07 AM
08/07/08 10:07 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks,
Darren
I have a 15a low beam and 20a high beam fuse. Depends on what bulbs you are running. Mine are aftermarket H4's.
If you take the resistance of the low beam filament, then divide 14 (avg voltage while running) by your resistance reading, then multiply it times to (bulbs). You will get the amperage draw for the low beams. I'd go up to the next size to account for any surge. And do the same for the high beam. (high beam filament will be lower resistance than the low beam).
Example
Bulb resistance 1.5ohms (just a random figure)
Avg running voltage 14v
14v divided by 1.5ohms = 9.3a x 2 bulbs = 18.6a (i'd run a 20a fuse)
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Four (4) Headlights on relay's ?........ [Re: Ludington1] #79787
05/16/13 06:50 PM
05/16/13 06:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm doing this now and found this old thread in a goggle search, so I'm it.
Re: Four (4) Headlights on relay's ?........ [Re: Challenger 1] #79788
05/16/13 10:15 PM
05/16/13 10:15 PM
BDW Online content
BDW  Online Content
Might as well add 1 for the running lights while you're at it.
Page 3 of 3 1 2 3
