Re: AVS Question - '69 383
[Re: 70mopes]
#797117
09/09/10 01:30 PM
09/09/10 01:30 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
yes 4-speed have them, BTW you also need the long leaver on the carb throttle shaft for it to work. To set up the dashpot adjust the idle adjust screw till your rpm is at 2K, then bring down the dashpot till it just touches the arm, then lock it down, bring idle back to normal & enjoy.
[Re: 70mopes]
#797120
09/09/10 09:54 PM
09/09/10 09:54 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Mine works well and will need a bit of TLC before it looks good enought to install however the rubber boot on mine is shot. Any ideas on how to fix that?
I have a dash pot I bought that was NORS and used it for a short time untill I found a NOS unit. It's for sale if you need one, PM me if interested.
