Re: Torqueflite Issue, strange one.
[Re: CHRYCOFAN]
#796427
09/08/10 07:11 PM
09/08/10 07:11 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Before anything else you need to get the shifter straightened out so the gear positions are correct; if the transmission lever is too long you will have either Park or 1st but not both.
With the shift linkage correct you can manually shift it to see if there is a second gear, if there isn't it might need a simple kickdown band adjustment.
