Re: Brake Fliud Gone Where?????
[Re: JohnRR]
#796080
09/10/10 06:42 PM
09/10/10 06:42 PM
Posts: 679 N.E Indiana
repad
super street
super street
N.E Indiana
The 1 I got on it isn't the spring clamp. It has a bolt and double eared piece that is about 3" long. I cleaned it off good this morning and drove it awhile and there is fluid back on the bottom of the master cylinder, I did have brakes when I drove it. I have another master cylinder now so I'm going to change them out. I just hope this fixes it. Ronnie
Take the cover off carefully and see if there is fluid on the top surfaces , also those surfaces are usually not smooth, have alot of scratches and will leak , I usually lap mastercylinders , especially rebuilt units , before instal to get a smooth sealing surface .
Also check that the lines are tight , if they are leaking you will have fluid under the master .
How do you lap a master cylinder lip?
[Re: Nukechargerboy]
#796082
09/11/10 01:20 AM
09/11/10 01:20 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
With a lapping block and lapping compound. Never did it but I'm pretty sure it's like lapping a gate valve disc.
I use a piece of fine emery cloth , full sheet size , double back taped to a surface plate at work , run it in a figure 8 pattern .
