Re: Brake Fliud Gone Where?????
[Re: okie]
#796062
09/09/10 01:54 PM
09/09/10 01:54 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I might have found it, the cap on the master cylinder isn't sealing good. I don't guess the chinese can't make a good rubber seal. I'm going to NAPA in a little while and see what they are going to do about it. This has to be it because there is no other leaks any where. Ronnie
That will only cause a leak when you apply the brakes , just sitting it will not leak ...
unless you installed it upside down ... kidding ...
[Re: Pyper70]
#796064
09/09/10 03:07 PM
09/09/10 03:07 PM
Posts: 1,222 okla.
okie
okla.
The block isn't leaking. After I pump them up you can find fluid on the bottom of the master cylinder. There isn't any fluid on the inside are out side of the master cylinder on the fire wall. I had drove the car for several days before it ran out of fluid. I have a new 1 coming in the morning so I'll change it out and see if that will fix it. Ronnie
[Re: okie]
#796065
09/09/10 05:52 PM
09/09/10 05:52 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
Look for missing paint. Brake fluid is very corrosive when it comes in contact with paint. If your master was leaking, your inner fender wells would have alot of discoloration / flaking
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: okie]
#796066
09/09/10 06:18 PM
09/09/10 06:18 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
After I pump them up you can find fluid on the bottom of the master cylinder. There isn't any fluid on the inside are out side of the master cylinder on the fire wall. Ronnie
Having a hard time following ya on this one.
[Re: 70sixpkrt]
#796070
09/09/10 09:39 PM
09/09/10 09:39 PM
Posts: 1,222 okla.
okie
okla.
[Re: okie]
#796071
09/10/10 08:44 AM
09/10/10 08:44 AM
Pyper70
Athens, Greece
Think what???
I'd be more worried about the moisture in my lines. DOT5 attracts condensation. DOT 3, is just fine, be careful when you use it around your paint and engine bay and you'll be fine.
Here is an excerpt from a website about all the grades "There are disadvantages to glycol brake fluid however. For one thing, the very attribute that enables it to accept moisture actually causes it to attract moisture, as any alcohol product will. For this reason, brake fluid suppliers recommend that only small amounts be kept on hand, and that a tight seal be kept on any unused fluid. (In the old days, it used to be available only in metal cans.) Another disadvantage, and a significant one, is that glycol fluid is chemically caustic, meaning that it damages other materials. It effortlessly removes paint and does strange things to plastic. (Even after it is wiped off, glycol fluid causes catalytic embrittlement, a chemical reaction on the molecular level that leads quickly to deep cracks. The ABS plastic used in motorcycle bodywork is especially susceptible.) "
[Re: Pyper70]
#796072
09/10/10 09:17 AM
09/10/10 09:17 AM
Posts: 905 SD
zrxkawboy
SD
Think what???
You've got it bass-ackwards. All the glycol stuff you quoted is about DOT 3/4. DOT 5 is silicone-based.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#796073
09/10/10 10:00 AM
09/10/10 10:00 AM
Posts: 417 jamestown, ny
71scamp440
Hinged
Hinged
jamestown, ny
Think what???
with you on this one. dot 5 wont peel your paint or discolor it in anyway. its silicone. all it will do is make your paint have the wet look until you wipe it off. and yes i know this from my personal experiences.
71 scamp
big block with 915 heads
727 trans
[Re: zrxkawboy]
#796074
09/10/10 10:09 AM
09/10/10 10:09 AM
Pyper70
Athens, Greece
Think what???
Sorry...my bad...This what happens when you multi-task and start drinking middle of the day
[Re: Pntastar69]
#796076
09/10/10 02:02 PM
09/10/10 02:02 PM
Pyper70
Athens, Greece
Could be either or....depends on the aftermarket MC you buy. Factory is a spring clamp with a rubber diaphragm on the inside
[Re: okie]
#796078
09/10/10 05:56 PM
09/10/10 05:56 PM
JohnRR
U.S.S.A.
The 1 I got on it isn't the spring clamp. It has a bolt and double eared piece that is about 3" long. I cleaned it off good this morning and drove it awhile and there is fluid back on the bottom of the master cylinder, I did have brakes when I drove it. I have another master cylinder now so I'm going to change them out. I just hope this fixes it. Ronnie
Take the cover off carefully and see if there is fluid on the top surfaces , also those surfaces are usually not smooth, have alot of scratches and will leak , I usually lap mastercylinders , especially rebuilt units , before instal to get a smooth sealing surface .
Also check that the lines are tight , if they are leaking you will have fluid under the master .
