94 Ram engine #795932
09/08/10 12:54 AM
09/08/10 12:54 AM
mt. airy, north carolina
casper 86 Offline OP
I have a 86 d-100 with a 318 and I have an engine out of a 94 ram 1500 What do I need to use this engine in my 86? Can I use the heads and intake off my 86? or what type intake can I use on the 94 heads?
Re: 94 Ram engine [Re: casper 86] #795933
09/08/10 01:44 AM
09/08/10 01:44 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you want to use the LA heads and intake on a magnum block...
magnum block oil thru pushrods....LA block oils thru block to rocker shafts...
you will need to find a way to get oil to the rocker shafts...
Tony
70 AARCuda Vitamin C
