Re: 67 Coronet Dual Snorkel Air Cleaner
[Re: BSB67]
#795778
09/08/10 10:31 PM
09/08/10 10:31 PM
Posts: 4,588 St. John's Newfoundland
440newport
Yes, they have pie tins, but I don't think they will fit a B body air cleaner as they are a different shape
Some of the 66 and 67 air cleaners have a small dimpled area in the middle that won't accept a pie tin...this type never had any from the factory but I've seen people use the decal version of the tins on these and make them fit. But there's no physical difference between a B and C pie tin.
[Re: BSB67]
#795782
09/09/10 12:00 PM
09/09/10 12:00 PM
Posts: 4,127 Ramona, CA
NicksGarage
Ramona, CA
Hmmmmm.
Hmmmmm indeed!
Do you have the bases for both of those? What about filters? My old Fram book doesn't show any options. I'll have to get my early '68 unsilenced one from my Barracuda out and measure it again.
[Re: BSB67]
#795783
09/09/10 03:55 PM
09/09/10 03:55 PM
440newport
Hmmmmm.
Well dang, I guess you're right. I never thought there was a height difference. Interesting because they all take the same air filter as far as I know.
[Re: NicksGarage]
#795789
09/09/10 10:01 PM
09/09/10 10:01 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Maybe there's a difference in base plates that account for using the same filter in all of them. I just don't have a lot of first hand experience the '67 air cleaners.
Ding Ding Ding. You guys are way smarter than me on this stuff. I think I'll just stay quiet now.
Interestingly, the carb mount is in about the same place (height)for both, meaning that the taller lid will actually sit taller above the carb than the 67 base/lid combo.
[Re: BSB67]
#795790
09/09/10 10:13 PM
09/09/10 10:13 PM
NicksGarage
Ramona, CA
No, please don't stay quiet! This is all very interesting. I'm always learning more about air cleaners. Now we just need to figure out what the taller '67 air cleaner is for. Is your Charger an original 440 car and had the shorter dual snorkel? I measured my '68 unsilenced air cleaner and it is the shorter height. These are actually the same as '67 unsilenced ones and were phased out in early '68. They then switched to the smaller diameter one that was being used on the 340s. The one below is not mine but the same. Of course the base plates would be different between '67 and '68. Mine has the same base as the 340 air cleaner.
[Re: killercoronet]
#795791
09/09/10 10:19 PM
09/09/10 10:19 PM
NicksGarage
Ramona, CA
Mine measures about 3 3/8 tall. Im running a Holley intake, its a single plane 4.13" front and 5.25" rear with a Holley carb. I guess the intake is to tall or something because it its on the back side.
Can you post pictures of the lid and base that you're having the problem with? The Holley would have to use the bigger diameter throat opening.
