Re: Cleaning White Letters on Tires [Re: GTXKen] #79412
06/25/08 02:21 PM
06/25/08 02:21 PM
scratchnfotraction Offline
simple green has worked for me also
but mostly the boat gets it
and dig those white walls
Re: Cleaning White Letters on Tires [Re: Paul_B] #79413
06/25/08 03:21 PM
06/25/08 03:21 PM
I've always used Westley's Bleche-Wite. You can find it at pretty much any place that sells car cleaning stuff.
Great stuff
Re: Cleaning White Letters on Tires [Re: 318 Stroker] #79414
06/25/08 03:55 PM
06/25/08 03:55 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I've used SOS pads for years now. They work great!
Cheap and effective, thats what I always used!
Re: Cleaning White Letters on Tires [Re: Finoke] #79415
06/25/08 04:17 PM
06/25/08 04:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I used to too!
But now I get some degreaser from work that we get from SC Johnson. Called J Shop, I think. It's a alkaline based degreaser. Can't use it on alunimun or painted surfaces but it the best stuff I've ever used. Spray it on,presuure wash it off. White walls are white and the black is black.(very clean) Been using it for about 15 years now. Stripped waxed floors with it, cleaned stainless restarant equipment, do my oily fuel trucks, grills. I could go on and on. We get it in 55 gal drums. Never have to touch a surface with it as long as you have a pressure washer to rinse. Have to use common sense where to use it though, it's powerful stuff, alkiline based I believe.We use it as a pre treatment on really oily cloths sometimes with diesel fuel on them. BTW I don't steal it from work, I own the company.
Re: Cleaning White Letters on Tires [Re: moparmike1] #79416
06/25/08 09:00 PM
06/25/08 09:00 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Westley's Bleche-Wite + a wire tire brush (brass bristles). Perfect.
Just get all that bleche wite off before it dries on things. It will stain.
Re: Cleaning White Letters on Tires [Re: njmopar] #79417
06/25/08 09:33 PM
06/25/08 09:33 PM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
I use rubbing alcohol and a clean old sock. Dip you finger covered sock in the bottle and wipe each letter, works wonders
