68 charger, charging issue. #793455
09/05/10 03:38 PM
09/05/10 03:38 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Hi All, my dad's 68 charger isn't charging. The car is a original one owner 318 car and isn't modfied at all. The issue came up after a motor rebuild and I haven't been able to trace the problem. Both the alternator and the voltage regulator are new. Any input would be appreciated! Here's what I've done so far.
Alternator ground is good with continuity verified between the alt case and the battery neg terminal.
Voltage Regulator ground is good with continuity verified between the case and the battery neg terminal.
If I run a jumper from batt + to the alt field terminal it starts charging.
With the car at idle I have 2.x volts at the field terminal when its connected to the alt. (couldn't read my note on what the .x was exactly)
With the car at idle I have 8.5 volts on the field wire when it is not connected to the alternator.
The field wire has good continuity from the alternator plug back to where it connects to the voltage regulator.
The alternator is a roundback unit, however It does appear to have two places where a field wire could attach. I'm not sure if thats normal or not for the 68 unit as I don't have the old one around.
Thanks for any and all input!
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: 68 charger, charging issue. [Re: blown340] #793456
09/05/10 04:10 PM
09/05/10 04:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the alternator has two male wiring terminals then you need two wires going to them. If I remember correctly one blue and one green. It makes no difference which goes to what terminal.
Re: 68 charger, charging issue. [Re: stumpy] #793457
09/05/10 04:18 PM
09/05/10 04:18 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Thats the thing, the car only has a single field wire. Is there such a thing as a dual field roundback?
Edit: Looks like I ended up with a 69+ roundback instead of the 69- I needed. "The first alternators used on Chrysler products was made by a company called Essex. The Essex brand Chrysler alternator can be identified by the wide spacing of the fins on the front and rear frames and will also have the Essex symbol cast into both of the frames. For the 1963 model year Essex continued to make the alternators for Chrysler, however they added more fins to the frames to give it added strength. Essex also produced the first mechanical voltage regulators for Chrysler and had the Essex symbol stamped into the metal case of the voltage regulator too. These were all single field, "B" circuit alternators. By 1964 Chrysler was ready to manufacture their own alternators which looked like the Essex brand but no longer carried the Essex symbol that was cast into the frames. These were produced in 37, 46, and 60 amp versions and all looked the same on the outside. Chrysler still retained the same "B" circuit, single field wiring design through the 1969 model year. In 1970 electronics were starting to come into their own and we started to see the electronic voltage regulator. When Chrysler went to the electronic voltage regulator the wiring design changed from the single field "B" circuit to the double field "A" circuit, which now had two field terminals on the back of the alternator. The frame design stayed the same and another terminal was added for the second field. This style alternator stayed in production through the 1971 model year. For 1972 Chrysler redesigned the alternator. The front frame stayed the same, but the rear frame changed considerably. Instead of the can type pressed-in diodes used in the earlier alternators, they now had a positive rectifier and a negative rectifier each containing the three diodes. These were bolted to the rear frame as two separate assemblies which made a common electrical connection that the stator windings also connected to. This style of alternator greatly improved the repair aspect as no soldering was needed to join all of the diodes and stator windings."
Re: 68 charger, charging issue. [Re: blown340] #793458
09/05/10 04:38 PM
09/05/10 04:38 PM
indiana
generallee6901 Offline
indiana
Run a wire from the other terminal to ground and it should charge.I usually run it to the alt. bracket or to the engine.
Re: 68 charger, charging issue. [Re: generallee6901] #793459
09/05/10 05:11 PM
09/05/10 05:11 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Is that a permanent solution, or is that just for testing purposes?
Thanks,
-Jon
Re: 68 charger, charging issue. [Re: blown340] #793460
09/05/10 06:39 PM
09/05/10 06:39 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Maybe that is what I need to do. On my 70 RR on my wiring I just have 1 plug on my wiring harness and mine isn't charging. So I need to hook a ground off the other spade so it will Charge? I hope that will work so I don't have to buy another alt. Ronnie
Re: 68 charger, charging issue. [Re: blown340] #793461
09/05/10 07:29 PM
09/05/10 07:29 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Is that a permanent solution, or is that just for testing purposes.
That would be permanent.You can ground it to the back of the alternator.
Re: 68 charger, charging issue. [Re: gtx69] #793462
09/05/10 07:37 PM
09/05/10 07:37 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Unfortunately grounding the 2nd fld terminal directly to the battery neg didn't have any effect.
Re: 68 charger, charging issue. [Re: gtx69] #793463
09/05/10 07:40 PM
09/05/10 07:40 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Picture of how i grouded mine.
Re: 68 charger, charging issue. [Re: okie] #793464
09/06/10 05:11 PM
09/06/10 05:11 PM
indiana
indiana
70 rr should have the 2 wires unless someone has changed or modified the wiring.
Re: 68 charger, charging issue. [Re: generallee6901] #793465
09/07/10 09:06 AM
09/07/10 09:06 AM
okla.
O
okie Offline
okie  Offline
O
okla.
On my 70 will it work if I ground the other terminal? I really don't want to buy another harness are alt. unless I have too. My harness is right for everything ECU and all other hook-ups but it just doesn't have 2 plug on wires in it. Any help on this will be a big help. I'm trying to get the car ready for the first show this coming Sat. Let me know. Thanks Ronnie
Re: 68 charger, charging issue. [Re: gtx69] #793466
09/07/10 11:39 AM
09/07/10 11:39 AM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
That's how my 68 is.
