Re: Holley Problems
[Re: chache876]
#792722
09/04/10 05:34 PM
09/04/10 05:34 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
Do you have the accelerator pump linkage clearance adjusted correctly?
I was wondering this also because I know you can move it up and down and also add those cams in there to change it... but was is "correct"? I'm assuming as soon as I hit the gas I should see it shooting gas in which would equal what you're saying? I have lots of dumb questions ![](/ubbthreads/images/graemlins/biggrin.gif)
Re: Holley Problems
[Re: MoparforLife]
#792723
09/04/10 05:37 PM
09/04/10 05:37 PM
68KillerBee
Missouri
You don't get a pump shot????? It should shoot even if the engine isn't running and you pump the gas. That is what the problem is. Need the pump shot.
Even with me opening the throttle all the way open I wasn't seeing any pump shot... Adjustment is WAYYY off? need a new accelerator pump diaphragm thing? Why would it run good with the choke on, but once it opens go back to running bad??
Re: Holley Problems
[Re: 68KillerBee]
#792724
09/04/10 06:06 PM
09/04/10 06:06 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
while the choke is on..the mixture is rich to help the engine run while it is cold..
the acelerator pump is a shot of gas to over come a lean condition as the throttle blades are opened....the pump shot riches up the mixture...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Holley Problems
[Re: 68KillerBee]
#792725
09/04/10 06:13 PM
09/04/10 06:13 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
Well I really can't comment on whether or not you need to change pump cams, but at WOT, there should be about .015" clearance between the accelerator pump linkage arm and the bottom of the adjusting screw.
The accelerator pump basically eases the transition between the idle speed circuit and the main circuits. If theres too much clearance, the carb basically starves for fuel in that split second when you punch it. The pump arm should start moving as soon as the throttle begins to move.
If that adjustment is within spec, you might need to go with a larger pump nozzle.
Re: Holley Problems
[Re: 68KillerBee]
#792728
09/04/10 06:31 PM
09/04/10 06:31 PM
70AARcuda
las vegas
Tony
