Cuda Woodgrain door panel inserts ? #791682
09/03/10 02:37 PM
09/03/10 02:37 PM
North Dakota
Azzkikrcuda Offline OP
North Dakota
Does anyone know if the top rear doorpanel woodgrain inserts are the same for the driver and passenger side? I found a guy with a pass. side and I need a drivers side.
Re: Cuda Woodgrain door panel inserts ? [Re: Azzkikrcuda] #791683
09/03/10 04:59 PM
09/03/10 04:59 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the curves are different...i believe....
Re: Cuda Woodgrain door panel inserts ? [Re: Azzkikrcuda] #791684
09/03/10 06:42 PM
09/03/10 06:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
AB,...I looked at my Cuda Red Bar panel inserts, and while there's an extremely slight curve along the horizontal line, I see no reason why you can't tweak the metal backing on the strip to make it fit the opposeing panel
Re: Cuda Woodgrain door panel inserts ? [Re: DAYCLONA] #791685
09/03/10 08:30 PM
09/03/10 08:30 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Mike, I wonder if the attaching tabs are symmetrical for the flip side attachment...
